front coil spring swap
Guys are making lift kits on here cheap! Out of 2" square tubing...not sure who, but saw it on here somewhere.
Need to remove pin to get shifter knob off on 1990 loyale push-button 4x4
Find something that fits the pin size and drive it out...I haved a small screw driver with the end cut off.the screw just holds in the button.
4wd indicator switch - where to get a new one?
The self service wrecking yards here have lots of subie parts...not sure about your location...but its a cheap part.
I have one that I have left over from a swap...not sure if the plug will be the same...although its just two wires to spice a new plug on.
Northwest Native
Awesome to find one with miles like that! Sweet find!
Hello from Eastern Washington
Hello fellow Loyale owner! Got a 93 and love mine..but it been quite the job fixing all the stuff that was wrong with it...rack and pinion, motor, dual range conversion, now it needs wheel bearings...but I love this thing! Pull and save had all the parts!
waz up from North Idaho!
Nice to see people from north Idaho in here! Subarus seem to rule the roads up here, but you don't see the older ones as much...most are rusted out from years of heavy use!
my 92 loyale build
I have a 93 Loyale and alread did the dual range swap...the pull and save up here has a ton of subys! I want to do a ej22swap next, my buddy has the donor car, a 92 Legacy...but my question is where do I get the adapter plate?
Nrw to the site.just want to say found lots of great stuff on here be for I joined! Just got done doing a motor anf trans install in my 93 Loyale! Changed it to a dual range...next is an ej22!
Torry3393
