swilde20
Everything posted by swilde20
no start
swilde20 replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
tried putting car in neutral and still no start. had one thing which leads me to believe it's a electical problem. turned key forward and had no power to windows with a fully charged battery. -
	i have a 95 legacy wagon 2.2 automatic 2wd . had a no start the other day, replaced battery no change, so i replaced the starter and still no change. i can't see were there's a starter relay on a automatic unless i missed it in the pictures. so if anyone has any ideas i would like to here them. thanks steve
	2.2 engine, Going 25 mph when it went took off the heads and saw very little in the way of marks on the heads or pistons. what kind of problems have people had with interferance when the timing belt goes, and what else should i look for. going to take the heads to the local Bumper to Bumper to have them checked. let me know steve
	has anybody tried to buy one of those motors from japan? I bought a 97 gt that the guy put a nice 2.2 in it but i thought i would put that in another car and go back to the original 2.5 but i find they all came from automatic cars and i have a 5 speed. So i was wondering if there is a way to make it work or if i would have to get a different intake. So if i could get your input that would be great. Thanks Steve
	i have a 97 legacy outback limited with a 2.5 and automatic that has a bad trans. i'm not sure how to tell what the ratio is to put in a new one. i have a trans from a 96 legacy outback and 2.5 but i'm not sure if it will work. i got the numbers off the tags under the hood and didn't know if those would help. (1) is tz102zaba (2) is tz102z2cba. HELP!!!! thanks steve
	iv'e done this several times and never had a problem until now. i'm putting a 2002 wrx 6 disc in my 96 legacy outback, when i plug it in i hear the cd player turning on but when i go to turn it on i get no joy. anybody have any ideas? thanks steve
	all 4 come out of 1 connector, then there is wires going to the 3 different bulbs. thanks steve
	i bought a set of projection headlights from a 97 outback and was wondering if anyone could tell me what i needed to do convert the wiring? stock has 3 wires and the projections have 4. thanks steve
	i'm looking at buying a 97 legacy wagon that has no power windows and a tach less dash and was wondering if the wiring was there from the factory if i was to put on some other doors i have with all the power options and a different gauge set with a tach? i know some car builders do that to save time and money. thanks steve
	2wd auto to a 4wd auto. thanks steve
	other than the obvious things like the transmission, driveshaft and rear end what other things would have to be changed to make a 2wd into a 4wd? thanks steve
	other than the obvious things like the transmission, driveshaft and rear end what other things would have to be changed to make a 2wd into a 4wd? car is a 95 legacy 2wd, parts car is a 95 4awd legacy thanks steve
