Billy G.
  1. grossgary Thanks!! I will also check subaruxt.com Bill
  2. Thanks Crazyeights!! Has the mod done. I will do some more checking. Bill
  3. Every once in a while my power steering on my 1989 XT6 just stops working. It happens after I have stopped for awhile, turned the engine off, and then start up again. Most the time after I drive it some it goes back to normal. Sometime if I stop and shut off the engine and start again it is okay? Fluid checks good when hot or cold. What could be wrong? Thanks, Bill
  4. Anyone have subject emblems in new or NOS for sale? Having my 89 XT6 painted next week and though be nice to replace the emblems. Billy G. in North Florida
  5. The 87 Brat was listed for $11,900 on there lot before it was put on eBay the first time. First time I bid $6300.00... No sale for last 3 or 4 times. Bid has gone over 9K once. No sale. Billy G.
  6. 89 XT6... 2013 Mini Cooper 2004 Chevy SSR Billy G.
  7. Where is the best place to order touch up paint in spray can? I need 8-12 ounce can of Pewter Metallic #944. Thanks Billy G. in Florida
  8. May have the lens... check my items: www.ebay.com/usr/w4wx Bill
  9. Thank all for your responses!!! Great help. I think I will be able to remove the brushes and clean or replace them. I ordered the correct fluid from a Subaru Dealer in Jacksonville.... If not too difficult I thinking I should change the fluid. With 160,000 miles and not knowing the history probably needs changing? Don't forget to check my 70/80's parts on eBay: www.ebay.com/usr/w4wx I add new parts each weeks. Thanks again! Billy G. in North Florida
  10. On the way home from getting a new battery installed in my 89 XT6 I stopped to drop off a UPS package. Leaving the UPS store parking lot to go home I lost my power steering. Very hard to turn wheels. The Steering warning light came on. I was only couple miles from home so carefully started that way. Couple blocks down the road the power steering came back and warning light went out? Got home popped the hood to check what I could. Belts were tight. The power steering fluid was little low. Was getting dark so went in the house. I assume when the warning light comes on it is an electrical problem? What do I look for tomorrow. Also, need to add little fluid. I purchased some Pentosin CHF 11S power steering fluid (oil for central-hydraulic systems recommended by BMW/Mini) for my 2005 Mini Cooper few months ago. Will it be okay to top the fluid off with this? Another dumb question: Do I need any external equipment to use the self-diagnosis system? Thanks, Bill in Florida
  11. I have few factory stripe kits on ebay. My ebay I'd is w4wx. Have other kits and parts alone. Billy G
  12. Need index pages : all after 1-N18 for my 86&87 Parts Catalog # ABU7-04. . Can someone help? Thanks Billy G. in Florida
  13. Would you have the parts catalog for 80"s... Billy G.
  14. I had same problem on 2005 Mini Cooper. Turn out to be a slight bent drive axle. Billy G.
