Everything posted by 84 Bruiser
83 GL-10 auto to manual
Found my answer.
Anyone know if a petal assembly from a 82 GL 2dr hatch 4x4 with H/L will work in my 83 GL-10 auto to manual conversion?
83 Turbo Wagon
Just went to Longmont Co and grabbed that turbo wagon. Back in Missouri with it now. Only 4hrs left till home. Cars doing great, getting 30mpg.
84 GL Wagon 4x4 Took front seats out and moved tracks forward 1 3/4". I'm over 6' and wow big upgrade. Took about an hour. Also removed the rear seat bottom from hinges, now I can fold the back down onto the hinge supports with seat all the way back and recline.
EA81 Coolant Bypass
Can it be removed ? Im still using the hitachi carb.
Runs Good, Runs Hot, White Smoke, New Intake Gaskets
Before start up,Pull all plugs and check for fluid in chambers.
Sounds like head gaskets. With cool engine, remove radiator cap, start and check for bubbles.
Trailer tires on a Soobie/Small car?
24.7" OD Same as 195-70-14
Amazon Maxxis 185-80-13 $ 99 But it's a white wall
Possible AWD Failure On a Manual and Still Drive OK?
84 Bruiser replied to roadsubiedog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould it be the spare tire fuze ?
Where can i buy an engine rebuilt kit for EA82T engine?
Rock Auto has a kit for 1985 GL Turbo by DNJ
Another heater question?
That vent tube is used to air cool older motors.
Missing and overheating problem. Need ideas.
84 Bruiser replied to Sawspa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith a cold start up, check for bubbles in radiator or overflow. If you get some it's probably head gaskets.
if its not one thing.... coolant loss, bubbles in overflow
84 Bruiser replied to bluedotsnow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like head gaskets
