rayban1
  1. The oil sending unit attaches to the block, I ordered a unit for a guage not light and it was to big of threads, only the sending unit for light fits on the block,I remember my 86 brat sending unit used the guage one, do you remember if it mounts to the block or oil pump? The threads or to big and it won't fit in space on block.
  2. Hi, been working on my 84 Brat. I have two issues. The ignition key cylinder get stuck and when I try to start it takes a few tries of turning the key cylinder and holding to get it to work, do I need to replace the whole cylinder or is there a switch? My oil pressure guage rises when I turn ignition on peggs out at top but then falls down and does not register, switch out oil sending unit and does same, car runs fine , think there might be a wire bad ground any ideas where to start, , thanks Ray in Seattle
  3. Thanks Speedwagon, did the rebuild went smooth. Rocket Seals was great, had the new o rings in a few days. No more leak. Great post . This is what USMB is all about, thanks again . rayban1
  4. Thanks for the repost, will give it a shot, rayban1......
  5. Looking for a hill holder valve for my 1986 brat, any one know what years and cars will work and where to find, Heading to local wrecking yards. Would 1987 gl be the same or even have them on it. Thanks rayban1
  6. My brat keep loosing brake fluid, traced it to the hill holder. Leaks even when the brat is parked. Have to add brake fluid as the light keeps coming on. Brake peddle is still strong. What should next step be? replace, rebuild, can you disconnect, Like the hill holder as it still works. Any ideas . thanks Ray........
  7. My washer pump stopped working the other day. When I pull the handle nothing, do not hear any noise. Any ideas what to check first, our is the pump just bad, original. Thanks Ray...
  8. Thanks for the info. The things i would ad is you have to use the bearings from your old lock cylinder, and there is a really thin retaining clip holding the larger bearing in place, took me awhile to get bearing out as almost impossible to see clip, thanks though .
  9. Cool thanks for the info, I will give it a shot tommorow .
  10. Hey guys have a 1986 subaru brat with tilt steering, replacing the ign key cylinder. Any tips on how to do this, ordered part just getting ready to remove old key clylinder, The new one comes with new keys and electric plug. Mine is toast. Thank Ray.....
  11. Thanks for the help, it was the fan switch. The old one had build up on the water sensor part....Ray .....
  12. sounds like the switch, tried the jumping the fan and checked for power to the switch and both are good. Will post results, thanks guys for the help.
  13. Is the temp sending unit and the fan switch the same part?
  14. I have a 1986 brat, the electric fan won't come on. Jumped the fan to test and it works, looked on the fuse panel and did not find one for the fan, all the rest are good. Just changed the thermostat because it was getting hot seem to correct that problem but fan still does not come on. Any ideas? Thanks Ray i
  15. Have a 86 brat, noticed the brakes felt like they were grabbing. Got home and jacked it up and all wheels spin except the left front. It stuck and won't spin. Calipers were replaced about 4 to 5 years ago, still alot of pad left on both. Any ideas how to release tension so it will spin or remove it. My master cylinder has had a slow leak think it the seals, but the fluid level is full. Have a hill holder also...thanks Ray....
