Everything posted by rayban1
84 brat
The oil sending unit attaches to the block, I ordered a unit for a guage not light and it was to big of threads, only the sending unit for light fits on the block,I remember my 86 brat sending unit used the guage one, do you remember if it mounts to the block or oil pump? The threads or to big and it won't fit in space on block.
84 brat
Hi, been working on my 84 Brat. I have two issues. The ignition key cylinder get stuck and when I try to start it takes a few tries of turning the key cylinder and holding to get it to work, do I need to replace the whole cylinder or is there a switch? My oil pressure guage rises when I turn ignition on peggs out at top but then falls down and does not register, switch out oil sending unit and does same, car runs fine , think there might be a wire bad ground any ideas where to start, , thanks Ray in Seattle
The hill holder, explained(or how to rebuild it)
Thanks Speedwagon, did the rebuild went smooth. Rocket Seals was great, had the new o rings in a few days. No more leak. Great post . This is what USMB is all about, thanks again . rayban1
Thanks for the repost, will give it a shot, rayban1......
86 brat hill holder
Looking for a hill holder valve for my 1986 brat, any one know what years and cars will work and where to find, Heading to local wrecking yards. Would 1987 gl be the same or even have them on it. Thanks rayban1
1986 brat hill holder leaking
My brat keep loosing brake fluid, traced it to the hill holder. Leaks even when the brat is parked. Have to add brake fluid as the light keeps coming on. Brake peddle is still strong. What should next step be? replace, rebuild, can you disconnect, Like the hill holder as it still works. Any ideas . thanks Ray........
1986 Brat Washer pump
My washer pump stopped working the other day. When I pull the handle nothing, do not hear any noise. Any ideas what to check first, our is the pump just bad, original. Thanks Ray...
1986 subaru brat ign key cylinder repair
Thanks for the info. The things i would ad is you have to use the bearings from your old lock cylinder, and there is a really thin retaining clip holding the larger bearing in place, took me awhile to get bearing out as almost impossible to see clip, thanks though .
Cool thanks for the info, I will give it a shot tommorow .
Hey guys have a 1986 subaru brat with tilt steering, replacing the ign key cylinder. Any tips on how to do this, ordered part just getting ready to remove old key clylinder, The new one comes with new keys and electric plug. Mine is toast. Thank Ray.....
1986 Brat electric fan
Thanks for the help, it was the fan switch. The old one had build up on the water sensor part....Ray .....
sounds like the switch, tried the jumping the fan and checked for power to the switch and both are good. Will post results, thanks guys for the help.
Is the temp sending unit and the fan switch the same part?
I have a 1986 brat, the electric fan won't come on. Jumped the fan to test and it works, looked on the fuse panel and did not find one for the fan, all the rest are good. Just changed the thermostat because it was getting hot seem to correct that problem but fan still does not come on. Any ideas? Thanks Ray i
86 brat left front brake caliper stuck
Have a 86 brat, noticed the brakes felt like they were grabbing. Got home and jacked it up and all wheels spin except the left front. It stuck and won't spin. Calipers were replaced about 4 to 5 years ago, still alot of pad left on both. Any ideas how to release tension so it will spin or remove it. My master cylinder has had a slow leak think it the seals, but the fluid level is full. Have a hill holder also...thanks Ray....
oil pump removal 86 gl hatch
Also leaving the oil filter on to help rotate was helpful , thanks again....Rayban1
Thanks got it , just needed that gentle tap.......
I have a 86 gl hatch 1.8L, trying to remove the oil pump. Have removed the 4 10mm bolts, pump rotates slightly but won't give. Am i missing something. Thanks Ray.......
86 GL Hatch Clutch/ Start problem
I took the starter out of my brat and stuck it in my wife's hatch. Just to make sure it was not the starter. It did the same thing. So I am pretty sure it is the ignition switch. Tried the relay but it kept blowing the 15 amp fuse. If I replace the ignition switch is it the whole key cylinder or is there a seperate ignition switch on the colum. thanks ray......
installed bosh relay, easy install. Works for about 5 starts then blows 15 amp fuse in new relay. Any ideas why fuse is blowing, what should I do next replace ignition switch or starter. Already jumped starter and it starts when jumped , thanks ray in Seattle.
Gloyale, any special relay your talking about is there a part #.
Ran a wire like you guys said, and it started , tried it 10 times started every tilme. So sound like the starter ok, but I guess it the ignition switch. It's my wifes car so sort of interested in a new ignition switch. Any idea where to get one if you still can and how much to have someone install. Thanks Ray in Seattle
Skip, how can you tell if it's the starter or the ignition switch. When i turn the key nothing happens no cranking, but then if i hold it long enough or try it again it will crank over. Sometimes it might take 1 to 5 tries, but getting worst. Checked on a starter today at Napa $95.00. Want to buy it but wondering what if it's the ignition switch are they still available. Thanks for your help Ray in Seattle...........
My wifes 86 gl Hatch is having a hard time starting. Not the battery and clutch works fine once car is running. Wondering if there is a switch or adjustment that let the car start once the clutch pedal is pushed in. Problem just started and is getting harder to start, have to pump clutch sometimes for it to start. Any ideas? thanks Ray...............
1986 gl hatchback tail light
thanks GD, thought I was missing a step . Rayban1
