ktperry
  1. Does anyone know if a 1983 Brat turbo fuel pump will work on a 1984 brat turbo? Thanks
  2. Does anyone have an idea what a 3 speed auto tranny weighs? Its out of a 1983 Subaru brat turbo. Thanks for any help i get ktperry
  3. If its only two or three years old it may have it, but just about all of the new ones have it.
  4. Thanks again. Does anyone have a picure of the flexplate and the torque converter? It would be helpful to know what I am looking for. Thanks Kevin
  5. If you go with the GPS get one that has WAAS technology. Its more accurate. Kevin
  6. I'm pulling my engine out of my 83 brat turbo. I was wondering how many bolts to remove where the engine and flywheel meet(I thinks it called the flywheel the part in front of the drive axles)? Also if you can tell me where the bolts are located? Just like to say thank you I couldn't of done any of this with out USMB. As you can tell I'm no motor head. Thanks Kevin
  7. Does anyone know to weight of an EA81? Estimates are fine too. Thanks Kevin
  8. Does the EA81T use the same pistons as the EA81? I know some turbo cars use low compression pistons. Also does anyone know what the compression should be in an EA81T. Kevin 1983 Subaru Brat Turbo
  9. Thanks Ross and everyone else who has helped me
  10. Im removing my engine and was wondering where do you disconnect the engine from the tranny. Be fore the drive axles or after.Thanks for all of your help. I couldn't of pulled it with out you guys Kevin
  11. whats is the sites address? I would like to check it out. Kevin
  12. I have a 1983 Brat with a EA81T and I was thinking of getting a Ea82T for it is it worth the work to convertit or just to rebuil the EA81T? Will I get a lot more power out of the EA82T? And how hard is it to convert it. Is the wire really hard? Thanks
  13. Thanks for thr reply
  14. What years and cars had the EA82 turbo engine in it? Thanks Kevin
  15. I have a 1983 Brat Turbo. Does anyone know the brand name of the distributor andthe part number or where I would find the part number? Thanks Kevin
