Wolverine18
Everything posted by Wolverine18
  1. Thats what i thought for a little while. What do you do. Clean the gas tank?
  2. So i replaced the cts didnt work. I like the description of the stumble. If the car sits for a couple days it starts but if i turn it off right away. I tried it again and it stumbles and then wont start. What would clog the fuel injectors?
  3. Thanks ill try that over the weekend. Any good websites for parts
  4. Hi, Ive had an 86 Gl-10 turbo for about 4 months. I've had an issue with the car not starting just about every month. The first time i replaced the spark plugs, wires, coil, cap and rotor didnt start so i had it towed to a mechanic. Of course it started right up for them. I drove it around for a month thinking it was fixed and it happened again. This time i took the fuel injectors off and sprayed them all out with carb cleaner and it fired right up. Drove it for another month and it happened again brought it to a subaru machanic and it started right up for them. Each time this has happened it has almost started but just kind of putters out. The car turns over, fuel pump is coming on and all electrically seems to be working. I thought that there could be a bunch of rust and build up in the fuel tank and the might cause the fuel injectors to clog. But wouldnt the fuel filter block that? i dont know, please let me know what you guys think. Thank you very much
  5. Hi, Ive had an 86 Gl-10 turbo for about 4 months. I've had an issue with the car not starting just about every month. The first time i replaced the spark plugs, wires, coil, cap and rotor didnt start so i had it towed to a mechanic. Of course it started right up for them. I drove it around for a month thinking it was fixed and it happened again. This time i took the fuel injectors off and sprayed them all out with carb cleaner and it fired right up. Drove it for another month and it happened again brought it to a subaru machanic and it started right up for them. Each time this has happened it has almost started but just kind of putters out. The car turns over, fuel pump is coming on and all electrically seems to be working. I thought that there could be a bunch of rust and build up in the fuel tank and the might cause the fuel injectors to clog. But wouldnt the fuel filter block that? i dont know, please let me know what you guys think. Thank you very much
  6. Duuuuuude!!! I have an 86 gl-10 with the same issue. Ive had the no start issue three times everytime i tow it to my machanic it starts right up. I have a theory. The second time it happened i took the fuel injectors off and sprayed them with carb cleaner. Put them back on, it fired right up. I think whats happening is the gas tank has a bunch of spoob in it. Every so often some spoob goes through the lines and clogs the fuel injectors. I was going to sell it but i dont want anyone to have the same issue or get stranded. I was think of buying a knew gas tank and putting it in. What does everyone else think of that.
