courtwarren
Posts posted by courtwarren
Also replaced alternator that comes built in voltage took care of surging voltage thank you
key dose have spring tension ,only occasionally dose it start the engine the rest of the time nothing,turn key and its like you hadn't done anything no click that i'm hearing,no starter noise amp gauge has no movement , in that start position, in key rotation if I push in a little harder on key not to turn more but in it then -sometimes- starts Parts store told me tilt steering ignition was one long continuous system of wire an harness from key all way down steering column to firewall? ?And thats why I want to instal a push button for starting just need to find right wire is that right?
the 2 sites look to be for without tilt steering and I can not find anything about starter relay for 85 brat may it be called something else, partsgeek going to get back to me 48hr
first off thank you turn key to power everything lights up bells chime ,turn more to start may start first time or nothing , might turn a dozen times until it starts .when it starts, it starts strong runs good.Thats why I thought it maybe ignition switch or module, Did Not know of relay , is it inside or under hood?
just got 1985 brat seems to start maybe a little better when cold not (consistent) and it will start after warmed, but need to play with key kid I got it from said just put new starter in it ,but I dont know if maybe he did replacment thinking this problem was that.Next they want little over 200 for new Ignition switch because of tilt steering -can I bye pass it with push button ? and would it be easier to get to what wires I need? to it under hood-hard for me to get down and fit under dash.Or could it be module or something else completely ?Also when I started it today the amp gauge started jumping from 12 to 18 volts , unrelated? ? thank you for your time court
1985 brat locked step box drivers side whats in there?
Posted
same as title whats in and how can i open?thank you
