532matt
  1. 1989 GL 4WD 5 speed 188881 as of today. Having some fuel/TPS issues.
  2. Is there an adjustment or reset on throttle position sensor on EA82. I've cleaned everything before installing extra throttle body and with new gasket and having problems with a slight sputter after shut down and a lag in climbing hills.
  3. EJ22 motor serial number question...if there is a link that can be shared to determine donor of EJ22EAA4GB-85 220767J610. Local dealership couldn't. Thanks
  4. My heater relay was bad after I replaced the switch and only had speed #3 working. Ordered new relay and while in shipment took old part out and overlapped the coil that was broken. Was a cold ride in that morning before problem was discovered 8 degrees to be exact!!
