Everything posted by steveb
Help! Air suspension problem - 1993/94 Legacy automatic station wagon
steveb replied to 1993 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes anyone know what the max. pressure is for the air struts? Also, I can see where the airline is on the front struts (right on top) however, where does the airlines enter for the rear struts? I read on another post that a few people put a shrader valve, either a "T" inline or one for each strut.
Air suspension system '92 Legacy
steveb replied to steveb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk thanks everyone. I will initially try to valve stem it as $ is a bit low. I will 1st look directly at the hose where it connects to the strut, then maybe where the 4 lines connect (by the compressor) If this all fails then onto coil struts.
Hi, I'm new on the forum. I have a '92 Legacy with air suspension. In ref. to the manually pumping up the struts/shocks: can I just connect to each air line (the line right out of the strut) an adapter (probably what is on the rim of a tire) and then just fill each strut with air? If so, then what is the max. pressure for each strut? OR If changing to regular struts I've noticed that the configuration near the top of each is way different. Looks like an air chamber as opposed to a coil spring. Can use some help on this as the struts have a mind of their own. Sometimes they fill with air sometimes not.
Air struts/shocks system
ok
Please help: Air suspension/compressor solenoid
steveb replied to hammer008's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi, I'm new on the forum. I have a '93 Legacy with air suspension. In ref. to the manually pumping up the struts/shocks: can I just connect to each air line (the line right out of the strut) an adapter (probably what is on the rim of a tire) and then just fill each strut with air? If so, then what is the max. pressure for each strut? OR If changing to regular struts I've noticed that the configuration near the top of each is way different. Looks like an air chamber as opposed to a coil spring. Can use some help on this as the struts have a mind of their own. Sometimes they fill with air sometimes not.
