Everything posted by ThoR294
2000 impreza rs Hissing sometimes at medium to full throttle, loss of power during this.
ThoR294 replied to Subardoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck for a loose vacuum hose. Spray around the engine with brake clean while engine is running, see if the car surges.
98 Legacy L AWD 2.2 Wagon Auto Shuddering while turning
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlways forget about the filter. I probably should do it on the last flush. http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/A-Trsax-Filter-Kit/_/R-ATP18561_0456358427 This one?
Impreza L 5dr Acceleration Problem bellow 2,500RPM
ThoR294 replied to Lucasrh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdefine slow and sluggish. What engine do you have? does it feel like a misfire?
95 2.2 missing on #4
ThoR294 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas going to say. Cylinder needs spark/fuel/compression. Start swapping injectors/plugs and compression test lol. Good job
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWill do. Hopefully flushing it will fix it. Currently trying to figure out why cruise randomly doesn't work
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOops . The first flush made it sooo much better. Before it binded REALLY bad when I cut the wheel like 1/8th of a turn. I couldn't even drive the car. I had put it in FWD mode to drive it. After the first drain/fill, I am now able to drive it in AWD mode. I can feel the shudder on most 90 degree turns, but it is no where near as bad. I will try a few more drain and fills and try more posi additive. Good news on that I can rebuild just the clutch packs without re-doing the whole trans. Any recommendations on where to get the parts/write ups on how to do it?
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I put the FWD fuse in, the binding stops. The binding is only there if the car has the AWD enabled (FWD fuse pulled). are you just saying to leave the fuse in when I drive it, and only pull the fuse when i do a drain/fill?
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMakes sense. So keep driving it and flush it with the fwd fuse in? How will I know if the shuddering stops though
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelp heres an update. The grinding noise out of the right rear was the backing plate. The bottom was rusted and hitting the rotor. I smashed some of it out and cut some of it away. It is mostly gone now. It is KIND OF there, but gone. Bearings are fine. Put 4 wheels and 4 new tires on it. I can now safely go over 40MPH lol. I did a trans service, the fluid was sooooooooooo brown. I put 4 quarts in like a moron, so it was overfilled, and I added 3OZ of GM posi additive with it (spoke with a seasoned scubaru tech, he said he does it all the time to cure it). I drained it down till it was properly filled. The shuddering has toned down A LOT. It is only there at extreme turns. So maybe keep flushing it?
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWill do. I am going to fix the tires first... as I can't even drive the car! Picking up a set of 15" legacy WHEELS (not ugly steelies) this Friday. will then investigate wheel bearing
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFixed right rear caliper, replaced rear brakes. Found left rear tire has a flat spot. Could maybe cause the "torque binding?" Its bad like can't even do over 55 lol (vibration from tire). Also found the bottom parking shoe spring on right side is hitting abs wheel? It hits hard when making a right but doesn't hit when making a left. Bad bearing?
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am on my way now to get fluid.
Whoopdie do for my freaking Subaru!
I had an 86 vf500 interceptor as well haha. Yeah Hazelton has many Subaru's!
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwesome thank you. Put fwd fuse in for now. Will buy additive and trans fluid. The fluid is BROWN in the car
ThoR294 replied to ThoR294's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah that is what I thought. I'm not sure how subaru's AWD system works either, so I don't know if its the rear or the trans causing the binding. This is the thread I was reading on. http://www.subaruforester.org/vbulletin/f88/do-i-have-differerential-transmission-issue-awd-binding-39121/
I have done some googling and am finding some mixed information. I am driving the car home tomorrow, so I want to have everything ready so i can fix it all at once. I noticed when turning it feels like the rear wheels are locked together (like the posi unit is shot, for example). The tires are all the same size, so that is eliminated. I read that changing the fluid and adding GM Posi additive (which i have, because i have a 96 trans am) to the rear AND/OR trans??? fixes it? This is the part that confuses me, as I have no idea how the AWD subie system works. do I put that posi additive in the TRANS along with the ATF fluid AND in the rear along with the gear oil? Thanks!!
Sup guys. Long time car guy... worked for Toyota/Hyundai for 7 years then decided to change careers into the IT field. Always fixing everyone's PCs/Cars. Anyway, I am a chevy guy at heart, but love everything! I have a bunch of cars... 1996 Pontiac Trans AM WS6, 1992 Dodge Dakota 2WD 4Cyl 5Speed, 1986 Honda Interceptor VFR750, 2009 Pontiac G5 Automatic turd. I previously had a 94 v6 firebird, 94 v8 6speed formula firebird, and a 97 Honda Civic EX with a JDM B18C Type-R swap (all 3 sold). Here's my pride and joy. 96WS6 6speed Trans Am with the fabled LT1 (OPTISPARK) wahoo. My bike + WS6 heres my civic. JDM yo my dakota with 1st gen durango wheels (summer tires). stock wheels have studded snows! Now for the reason I am here. Picked up a 1998 Subaru Legacy L Wagon White AWD Automatic with the 2.2L. $700. (no pictures yet, sorry!) 180k miles. It is in decent shape, only issues I see are right rear caliper isn't working, and it has LSD issue during sharp turns. Front end is a little rough (hood is dinged up and grill is missing). Nothing a run to local Harry's U-Pull-IT won't fix. Super excited to own a Subaru! Pictures to come tomorrow.
