Downwash77
Posts posted by Downwash77
Hello, does anyone know what speakes will fit under the dashboard of a second gen, the jbl speakers that do fit are NLA and Ive wasted much time and money already with speakers that dont fit. Thanks
Free brat cap (second gen) and seats. They have been in my way long enough. Cap has been robbed of shocks, handle parts and cab seal, driver seat frame is quite collapsed cloth is all intact passenger seat is good. Jason 860 840 1005 first come first serve
My 4mt duel range transmission is out and the socket that the the shifter arm goes into is very worn, is there any fix for this, I presume replacement parts are NLA. Thanks
Thanks, this is what I was thinking, we have the perfect landscape for exactly this type of driving.
Just finished my ea81 with new rings and bearing, wondering if there is any break in recomendations, thanks.
I use clover lapping compound it's a silicon carbide grease mix. Any grit is available.
Ea81 Longblock for sale. This engine is from 86 brat and has hydro lifters. The engine recived all new gaskets last year it has a new water pump. One of the valve guides is pretty worn although it runs well. $200 Jason 860 840 1005 thanks.
Thanks very much, that's what I was thinking!
Hello, does anyone know if a 02 SOHC engine will work in a 99 legacy that is equipped with a DOHC engine (both 2.5) I ask because there are two cars on Craigslist that need engines with good bodies and I have a good engine in my 02 I suspect wiring diffrences would be the only factor. Thanks
Hello, I have a brat cap for sale, has a broken latch needs gas Springs and cab seal, otherwise usable condition $80 obo 860 840 1005 text for pics, thanks.
If the block material is weldable it will need to be welded. Some pics would help
Could you maybe switch the whole tierod where it is attached to the end of the rack, assuming you haven't figured somthing out by now.
On this note I find it intresting to state, the aerokopter using a ej25 runs around 5600 rpms throughout its whole flight!
I paid around 2k for my 83 wagon and for thr condition it was in i thought it was a good price.
I adjust it so it grabs as soon as possible and it will still shift, I take those pedal play values with a grain of salt
The wagon and hatchback are two different body styles so it stand to reason it is to narrow.
Whatever engine it is it needs a complete reseal, dosent get any esier than on ea81. And congrats on your new subie!
Thanks, and yes it's a 86, I'm working on a bracket for the headrests (I have the seats)
I ask this question because on my brat I have the headrests for the rear seats but there is no corresponding mounting holes for the headrests.
What online sources sell the CORRECT axle wheel seals, I don't have time to get them from napa. I'm reluctant to order them without knowing if they are correct, anyone vouch for a supplier that sells the correct seal? Thanks
Ngk plugs are recomended. I don't know if it's possible but can the coil be generating to much voltage.
Replacement Dashboard speak for second gen?
Posted
The opening for the driver side speaker is 3-1/4 so a 4x6 speaker wont fit.
