Why delete the EGR valve?
Gloyale, DaveT and Idosubaru are absolutely right ! I just wanted to add, that without any connector the LED on the ECU is showing the error why the CEL is on at the moment. With the black 1 Pin reading connector the LED shows also error codes from the past that are saved on the ECU. greetings Franz
Hi Jes1991, on my Subaru Leone Superstation Turbo (1987) with EA82T Engine i have a green (2 Pin-TEST-mode) connector and a black (1 Pin READ-mode) connector under the steering wheel. "Reading mode" is activated if the green one is disconnected and the black one is connected. Error-Blink-Code is visible on the LED light inside the ECU with Key-Switch ON and Engine OFF. If there is no error code saved on the ECO the led will blink you the car specification. greetings Franz
Project: Gallery of my Subaru
What is the KYB number for the front shock absorbers ?
Do you have a part number of the blower fan resistor ?
Monroe struts
What springs are you using for the rear Naked Buell ? They look quite new.
new rear spring coils
Thank you, the King Springs would be perfekt, but as I live in Italy delivery would be very expensive.
Hello, i need to replace my rear spring coils on a Leone Superstation Turbo (1987) because they are split in two. All the spare parts I found are out of production. Can you please tell me if anyone makes matching spring coils ? May be from an other car ? I wanna keep the rear at the same hight as i am to install the SJR 2'' lift and dont wanna add additional lifting. thank you ! Franz
What head gasket to use?
Hello, a bit offtopic, but maybe it helps.... Don't have a clue about the head gasket, but please use the OEM intake mainfold gasket. The OEM Subaru are double layer with metal reinforcement, other gaskets on the market are bad quality compared to the Subaru ones. (Talking from bad expirience with Japanparts gasket on a EA82T engine)
FYI, new 4x140 wheels are available
Hello, i called them and 4x140 mm is avaiable ! The only problem is, that 15x6 rims have maximum 3 inch backspace (0 offset) and the 15x7 rims have maximum 4 inch backspace (+12,7 mm offset). If you plan to put the wheels on a non lifted Loyale (L-series) with original 55mm offset rims they would be too mutch outside.
Thank you for the information ! Can you tell me if they have 15X6 rims with +55 or +45 offset (should be 5 inch backspace) ?? greetings Franz
Subaru Leone 1987 offroad rims
Hello, i have a non lifted Subaru Leone/GL Superstation Turbo (4x disk brake) and I wanna mount bigger wheels and rims. I plan to redrill the hubs for 5 or 6 lug and I can do the work with a CNC milling machine, so it should not be a problem. Can you tell me the options for steel rims (14inch or 15inch X 7) with 45mm or 55mm offset that look similar to the original white Subaru steel rims or the scorpion 14 inch rims ? My favorit wheel size would be something like 195/70/R14 or 195/60/R15 I spent a lot of time on online research and searching the forum for cool offroad steel rims in this dimensions but faild badly. I would be very lucky if you can help me and wanna thank you in advance ! greetings from Italy Franz Erlacher
st33lix
