Everything posted by Cyril
Thank you AdventureSubaru, I hesitate to go much higher than stock cause I don't want to start messing around with the other suspension components and angles and performance etc... I like the way the rig drives now, just want that maybe up to an inch at most in the back for carrying a bit of a load and mainly for looks. I already have a jacked up Dodge truck with about 8 inches on it so I am good on that front. And I know from experience that once you start lifting, number one it's addictive, and number two, usually many other parts start taking a beating and need to, or should be replaced, also of course performance suffers due to the more of a roll from a higher COG. K well I will start looking into Youtube vids on this, you make it sound pretty easy, will I need a floor jack, or stands, or can I do it all from inside at the top of the strut? Sorry maybe a dumb question and I'm sure I'll find out here soon with my research... Thanks again for your input. Cy
Thank you AdventureSubaru, that's what I thought... Even saw a YouTube vid on the making of these cutting board spacers, but never heard if they actually were installed or worked with the original length bolts. Glad to hear it can happen. Was the 3/8th height difference enough to see, and worth it in your opinion?
Hi friends, I would like to create a slight rake in the appearance of my 93 L wagon. I do not want a "Lift" just a bit more height back there. For looks mainly... From what I've read 3/8th inch strut spacers are my best bet, causing minimal suspension change and ease of installation. I have some questions as I've heard conflicting info... First will I need longer bolts for this size spacer or will the stock ones work, or can I create a counter sink for the nuts? Is this an easy project for the DIY? Also I can find no info here on the old Coil spacer option, yes the cheap, used to be called knuckle spacers I inserted in my Impala springs when I was a kid to jack the back up a bit. Anyone ever do that to a Subaru? I realize its a very cheap and possibly sketchy option but I'm really not looking to change much back there... Thanks Cy
Thank You, this is what I was hoping to hear as far as an install goes. I just don't know if I want to spend the time or the hassle for this particular project. Plus I don't mind admitting that electricity is not my forte when it comes to wrenching... I don't mind spending the dough to have a pro do it right, but I really wasn't sure what it may cost. I will check with my local car audio shops.
Thanks Heartless, good to know there is hope if I decide to install myself. I will look into the crutchfield site for sure if I go this route. And great to hear a specific option, Sony X-plode, did this system fit into your red L wagon, I think it was, without many problems? I believe we have similar year and make rigs.
Hi friends, After hella searching and link following I am coming to the conclusion that trying to install a simple new radio/CD and ipod/phone capable stereo is gonna be a nightmare. At least for me... I just want a new head unit, and new speakers in the same spots as the stock ones. I have no need for massive amps or what not. So...Anyone else here just throw in the towel and have like a Cartoys or Performance Auto Sound, where I live, install one? Is it expensive? Should I just get a system from Walmart and fight through it? And lastly anyone have a good basic brand and model that is on the less expensive side, that will fit my 93 L wagon? I am not a music system snob, I just want something that works... Any helpful experiences, stories or advice would be appreciated. Thanks! Cy
I recently bought a 93 Legacy L wagon. I already have a big raised Dodge Ram for anything rugged to do, and I wanted an AWD rig for longer road trips that still can maneuver in snow, rain and some mud, but mainly could perform well on the road and be efficient. Remember that when the Legacy came out there were no Outbacks, so the rig had to perform as is, and did, as the outbacks do now. Someday I may get an outback but the newer ones are starting to really look clunky and seem to be turning into way more of a bigger SUV rather than a wagon. With what my older Legacy can still do under adverse conditions, and how well it performs on the highway, right now it is the choice for me. My advice would be to get an older Outback that still has some wagon/car qualities and keep your jeep for the off road stuff. I've had two jeeps in the past and they are the best for the adventure driving In my opinion. Have fun!!
Cool heartless! Thanks for offering, if you are swapping tires I would love to see what you find out but no need to do it just for this. I am pretty sure that since I will be running the stock 14" wheel size, that the 205/70/14 or the 195/75 will work under my stock 93 just fine. Eventually I may want to go to a 15" wheel, then I will have to figure all of this out again, plus all the suspension mods, but for now I am gonna keep it simple and stock as far as wheel size goes. Call me old fashioned, but I like more rubber under my rigs rather than wheel. I have time before I buy, planning sometime within about a month. It has taken quite a while just to figure out the size I want (with all the help from you and Matt 167!) let alone now I gotta figure out the best brand! LOL Have fun bro, thanks!
Hey Thank you very much Matt! Without modifying the suspension, I want to get the biggest tire under there as possible without causing any rubbing or performance issues. Knowing the 195/70's will fit is huge! I really don't want to go much wider at this point than a 205. I've felt back there and there is not much room behind the back sidewall. I will actually measure though.. If anything, I would like to go taller however, so I am considering a 195/80 or a 205/70? Without you having to look anything up again, can I ask your professional thought on those two options? Again, Thank you. I appreciate your time helping to educate me on this... Cy
Hey Matt thanks for the great info again! If you do find out about the plus sizing on my 93 L wagon that would be awesome! So many different numbers out there, but I'm pretty sure as you say, the 195/70 14's should have the room, and still give me a bit more of a fuller look. The Viva looks OK and is pretty affordable about $310.00 rollin out the door for a set. But I may want to spend a bit more on something a little better, but I do like the Goodyear name. Thanks heartless, I will see if I can get the Kelly's here in town somewhere and check them out. I will have some snow to deal with here in eastern WA.
Thanks Matt, Interesting inside info!! I for sure decided on the 195/70/14 size (pretty sure it will fit my 93 L wagon fine), and have been looking at other brands, Goodyear Vivas and Assurance are available at Walmart for a fair price. Not sure I can afford the best, as you mention but I will try to find the Kelly's as well. I do appreciate your educated input, I have no prob outfitting my Dodge Ram with tires but these Subarus are all a new thing to me....
Good question Olnick, I want to keep this particular rig as close to stock as possible, not wanting to change much about the current suspension performance or look save just a few minor details (little bigger tires, and maybe a slight lift in rear.) This is my grocery getter and distance road trip rig. I also have a 98 Dodge Ram with about 6-8 inches of lift that I play around with for that type stuff. (When I can afford it!) I say I may change the wheel size later cause I just bought the rig about a month ago so just trying to figure it all out first before any major changes occur. If my needs warrant a taller ride than I will cross that bridge etc... I am thinking most of my future Mods on this one will be performance/engine related rather than wheels and tires...So prepare for a crap load of future questions! LOL.
First Time Suaru Owner 93 Legacy Wagon
Cyril replied to Ballenxj's topic in Meet n' Greet. Your USMB Welcome Center
Hey A.S. Thank you, I am gonna research Goodyear and BFG to see if they have the sizes I am considering in an all weather. Leaning toward a General Altimax right now, but I'm still a couple months away from purchase. Down the road I am sure I will want a 15 wheel, and a bit more height. Thank you for the specific info on the suspensions. I will look into it! -
Hey BB and Heartless, thank you. Right now I have Delta, Essex 185/70R14's (I never heard of them) and they will get me to the Fall. I do want to keep the original size wheels (for now) and after doing some comparison am thinking of keeping the same width 185 but going with a slightly taller 80 sidewall for a bit more clearance and beefier look. Still thinking an all season, and you are the second person I heard from about the General Altimax. Will see if they have the size I want. Heartless thanks for the info on room needed, It is pretty tight in there but I think I'm most constricted on the back side of the tire, I have an inch or so before the strut perch. pretty sure a 195 and the taller 185 would work without any mods. For now i am not concerned with lifting to much, your rig looks great as she sits though... I may down the road just try to make enough room for 15's and a bigger tire. Thanks again guys, Big Help!!
Hi Ballenxj, Looks like we are in the same sitch... I also just bought a 93 L Wagon and love it, and am looking for the biggest all weather tire to put on the stock 14 in wheels. I believe from what I've found out, is that a 195/70 R14 would fit just fine. I was also asking about a 205/70 but am thinking there wont be enough room for them? I have not heard of the 195/80's that Georg mentioned and am intrigued by that higher sidewall! (I am also happy to hear his opinions about the legacy!) Best of luck with your new rig! Cy -
Hey thanks BB Lots I did not know... I have the alloy teardrop design wheels that I believe were on a 94 or 5 impreza or legacy. I was told I could run 195/70 14's on them by my tire shop. I really just want more rubber under there not wheel so I was gonna stick with the stock 14's and a 70% sidewall height rather than a lower wider 60 profile. Yes I do get some snow so will be looking for an all season that tends better in that area. Maybe the 195's would be the best first option for me? Thanks again for sharing this info.
