Rstnall4
Everything posted by Rstnall4
  1. Alright, so I just changed the CTS, and it’s still having the same issue. Except now, it takes even more attempts to start than ever before, and when I did get her started and was driving down the road, she hesitated several times and then cut-off. super frustrating.
  2. I checked the MAF, cleaned the IAC, and waiting to test the TPS and ordered a new CTS (the one on it looks clean, as if it might have been changed before).
  3. I have a 94’ Loyale with 136k on her and she fires up first time every time out in the driveway. Driving and accelerating she does fine. If I run a few errands and turn her off, I’ll come back out to start her up, and she will take about 8 cranks to get her running. After she finally cranks, no issues. I have replaced the fuel pump (20+ years old, doesn’t hurt) and the fuel filter, no resolve. My next thought would be the FPR, so I purchased a Delphi one off of eBay and it’s identical, except the shaft going into the TB has a bigger diameter than the stock one. So my question is, am I missing anything that I have already considered or changed? It’s an older car and I’m trying to get her out on the road again and dependable. thanks in advance.
  4. Decided to working my wagon cause I was burning through gas at a crappy rate. Changed the fuel filter, cap, rotor and plugs. Cranked it up and nothing. It will turn over but won't crank. I have fuel, put the old cap and rotor on and nothing changed. Put a new coil on, no change. Triple checked firing order and wire orientation on cap. No loose connections, everything tight. Is it the distributor? ECU? Seems super odd since it ran just fine prior to this routine maintenance. Any help would be appreciated.
  5. Similar issue. Just changed the fuel filter, cap, rotor and plugs. Car was running and starting just fine but now, after changing all of these tune up parts, no crank. It will turn-over but won't crank. I have fuel past the new fuel filter, checked that. Triple checked firing order and wire orientation on cap. Placed the old cap and rotor back on to test that theory out. Nothing. Battery is plenty strong. I bought an Accel coil and hooked it up incase I fried the coil. Nothing. Could it be the distributor????
  6. Hello, I wanted to introduce myself. I just recently purchased a CLEAN 1990 Loyale. 122k original miles and rust FREE! Not sure what route I want to take her, either lifted with motor swap or sleeper with engine swap. More to come. Hit me up if there are any Loyale enthusiast around the Laurel area.
