jkast
Everything posted by jkast
Did a little research on the web if the motor is a 1996 it probably does have Hydraulic lifters. I may pull the valve cover just to take a look. I drove the car on the highway today for 20 miles it would not throw a code. (PO303) code did not appear till i let the car idle, Seems like the miss is more prevalent at low RPM.
The only code showing up is a P0303, What do you mean when you say HLA engine ? This car is a 1998 Legacy GT it was built with a 2.5, A previous owner did a swap to a EJ22. I only know that because I can read it on the block. I think the engine is a 1996 because the spark plugs do not go through the valve covers making it a non interference engine which were built 1990-1996 Also I think it has single port exhaust making it a 1995 or 1996. Do you think the miss could come from a improperly seated intake or exhaust valve? As for the injectors I do not own a noid light but i did check #3 with a test light and a meter for voltage. With the key on I had constant voltage when the engine was running I was seeing a pulse on the test light. Bill
P03/P04/P400
jkast replied to jkast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Anyone else have any ideas on why this engine is missing ???? Are those compression numbers close to were a 2.2 should be? -
P03/P04/P400
Cylinder #1 145 Cylinder #2 145 Cylinder #3 150 Cylinder #4 135 These were done on a cold engine and removed only the plug from the cylinder that was being checked. The car seems to run without a miss at times. Missing is most present at low RPMs under load. -
P03/P04/P400
The car has new plugs wires and i have swaped the coil the miss is always present -
P03/P04/P400
The car always seem to have a miss I don't think it was caused by the intake swap. -
Hey Guys looking for a little direction and were to go from here. I have done a lot of work to this car and need to get it through inspection. This 1999 legacy had a engine swap before I bought it and now has a 2.2. The previous owner did not have emissions so when I first got it I had to change the intake and get one with a EGR. This has all been done the car runs but has a miss on cylinder 3 & 4 and a EGR flow malfunction.Not sure were to go from here I put a timing light on spark plug wire 3 &4 and both are showing a erratic flash indicating a miss could the coil be getting a bad signal I swapped coils and the problem was still present. .
Help my battery keeps going dead Just bought a 1999 Legacy and having a few problems. One is I keep loosing charge to my battery. I have purchased and installed a new battery and this did not help.(New battery still goes dead) My alternator is charging around 14V so I am currently looking for some type of drain on the system. I just checked the positive post on my alternator and there is battery voltage to the post with the key in the off position . Could this be the problem? Thanks Bill
2.2 Ghost Codes
OK , I think that will be the plan. I will buy the 2.2 manifold and swap out the parts needed from my friends 2.5 to the new 2.2 . When its complete I will pull the 2.2 without the EGR from the car and install the new 2.2 with EGR and I should be fine. I will let you guys know how I make out when I am done. Thanks for all your help Josh -
2.2 Ghost Codes
2.2 Ghost Codes
Ok so I called Hanna's they will sell me the intake for $75.00 the EGR for $45.00 and he said he would throw in a tube. Would that be all I need ? What about the wiring harness and injectors. Some one also told me I will need to pull the head and have it drilled and taped for some type of connection. You Guys are very helpful but this job is making me nervous. -
2.2 Ghost Codes
So is this the only option I have to get this car to pass emissions? Sounds like a lot of work. -
2.2 Ghost Codes
Thanks Guys, Your info has been very helpful Not sure if the car has the EGR but I have attached pics of the engine and the ECU, -
Hey Guys, Just bought my first car a 1999 Subaru Legacy its a nice clean car with only 44,000 miles. Here is the problem The car has had a engine swap 2.5 out 2.2 in, not sure of the year of this engine but it does have a ignition coil with female ends and the exhaust looks like it is ported for each cylinder. My guess is the engine is a 1996 EJ22. The problem is I can not get it to pass emissions. I have no CEL on. The car has never shown a CEL except when the car is started then it clears like it should. When I plug in the scan tool I get a P0403 (EGR flow circuit malfunction) and a P0303 (Cly #3 miss fire.) Also under my IM monitors I have (3) systems not ready, Evaporative system, Catalyst and Exhaust gas rec not ready. The ECM in the car is a 22611 AD698 is this the correct ECM for the new engine? or could this be the original from Subaru for the 1999 Legacy. Any Help will Help Thanks Josh ,
