gbash55
  1. Hi, As I was driving across the state, 3hr into my 5hr drive I noticed my turbo quit working when accelerating and with an occasional whirling sound. Long story short I limped it back (2hr drive) to a subaru dealer after o’reillys told me the timing belt slipped/stretched/ needed to be replaced; turns out my oil filter failed and leaked causing the turbo to seize up with little oil left in the car. I’m currently getting quotes of $2500 for tearing down the engine plus a bare minimum of $3500 for the turbo to be replacement (w/o parts). What would you guys do in my position? The engine has close to 132,XXX miles for the 2006 baja and would rather not give up on it. I’ve read around and could maybe dodge the $2500 diagnostic by a quick look at the oil pan but the engine damage is a real concern (drove through the mountains for 2hrs). Should I just get the turbo replaced by a independent mechanic and hope that the turbo was my only problem? Where would you draw the line on fixing a car? (Everything is stock, 2.5L EJ255 H4 Turbo) Any advice is greatly appreciated -Thanks
