Damn, those All Drive Subaroo folks rok
Hi David,
I'm Isaac from ADS, I'll be helping you sort out your dual range enquiry to suit your
Outback.
We currently stock 1.447 and 1.196 ratio dual range gearsets. We are expecting delivery
of our billet 1.6 high-low sets early next year, but we have no confirmed delivery date.
There are several ways to immediately meet your needs with existing stock; either a
complete gearbox assembly minus center diff, or the loose gearbox parts required to
convert your single range to a dual range.
Option 1 - non assembled gearset.
The non-assembled gearset conversion kit includes all parts and gaskets you will need to
convert your own gearbox to dual range. You will need someone with some knowledge of
Subaru gearboxes to perform the disassembly, assembly and installation.
Option 1 includes the following:
? Inspected Hi/Low range gear set 1.447 or 1.196
? Hi/Low range hub and slider
? Main Input Shaft
? All necessary assembly bearings
? Side differential cups if required
? Dual Range housing assembly
? Complete transmission gasket and seal kit
? Front hi/low range snout
Total cost comes to $1475 AUD
Option 2 - complete assembled transmission with or without centre differential (viscous
coupling).
A complete dual range transmission assembly in two price ranges, Level 2 and Level 3. Due
to freighting costs neither of these options includes the center diff, but one can be
provided as part of the assembly if required. This will cause some additional shipping
costs.
The level 2 gearbox contains a serviced/reconditioned standard OEM gearset, which is
suited to an individual seeking an OEM compliant replacement gearbox. Comes with 12
months or 25,000 km, whichever comes first, warranty.
? Inspected and overhauled factory Hi/Low range gear set at 1.447 or 1.196
? Inspected hubs and sliders
? Inspected synchronisers
? Inspected gearbox bearings
? Hi advanced bead blasted gearbox case
? Complete serviced fork and rod kit
? Serviced front differential
? Set to strict ADS specifications.
Level 2 gearbox is $1950 AUD
LEVEL 3 transmission assembly includes the following:
The level 3 gearbox is the best option for reliability and longevity without any vehicle
modifications. It comes with 24 months or 50,000 kms, whichever comes first, warranty.
This option includes:
? High/Low range gear set 1.447 or 1.196
? Revised 1-5 gearset (caroius ratios avaiable)
? Strongest turbo 3/4 gearset
? Lever action 5th gear hub
? New revised hubs and sliders with ball shift
? New gearbox bearing kit
? New revised synchronisers
? New OEM gasket and seal kit
Level 3 gearbox is $2450 AUD (minus centre diff assembly)
Optional ISF and shot peen strengthening process $650 AUD
The available transmission ratio's
The dual range transmission comes in two ratios, either may be used depending on the
application.
The 1st and 2nd gears have 2 variations 3.454/2.062 or 3.54/2.11
The 3rd and 4th gears have 3 variations 1.448/1.088 or 1.36 -0.97 or for the late series
2 only 1.29/0.97
The 5th gear has 4 variations .738 or .781 or .825 or .875
The high low range ratio has 2 variations 1.447 or 1.196
The final drive ratio has 5 variations 3.7 or 3.9 or 4.11 or 4.44
Additional items that may be required when installing dual range conversion kit to either
option 1 or 2 may be purchased from All Drive Subaroo
? Centre body interior console $125 AUD
? Dual Range lever and cable mechanism $40 AUD Used part or new part $150 AUD
? Hand brake handle unit and cable $150 AUD
? Clutch kit assembly is optional
? Front LSD differential units is optional
? Centre diff bearing kit $220 AUD
All options are available and ready for dispatch within 2 to 3 days.
Our usual freight company is TNT, whom we have found to be overall the most reliable and
cost efficient company. All consignments are fully insured and your cost would be
confirmed if an order is made. You can if you wish arrange for your own freight.
Please let me know if you wish to place an order or need any additional information on
these products
The ADS team and I look forward to being of service to you.
With Kind regards
ADS Team
Isaac Fam
