davygrvy
Everything posted by davygrvy
  1. I can't seem to find a listing with AUDM/JDM D/R transmissions in them, though. Here's the US ones
  2. There's this at the moment. http://www.ebay.com/itm/192167586049 I'm not sure based on the numbers what reduction it has, but I'd assume 1.19 if it came from an EJ25. EJ20 had the 1.449, I think.
  3. Damn, those All Drive Subaroo folks rok Hi David, I'm Isaac from ADS, I'll be helping you sort out your dual range enquiry to suit your Outback. We currently stock 1.447 and 1.196 ratio dual range gearsets. We are expecting delivery of our billet 1.6 high-low sets early next year, but we have no confirmed delivery date. There are several ways to immediately meet your needs with existing stock; either a complete gearbox assembly minus center diff, or the loose gearbox parts required to convert your single range to a dual range. Option 1 - non assembled gearset. The non-assembled gearset conversion kit includes all parts and gaskets you will need to convert your own gearbox to dual range. You will need someone with some knowledge of Subaru gearboxes to perform the disassembly, assembly and installation. Option 1 includes the following: ? Inspected Hi/Low range gear set 1.447 or 1.196 ? Hi/Low range hub and slider ? Main Input Shaft ? All necessary assembly bearings ? Side differential cups if required ? Dual Range housing assembly ? Complete transmission gasket and seal kit ? Front hi/low range snout Total cost comes to $1475 AUD Option 2 - complete assembled transmission with or without centre differential (viscous coupling). A complete dual range transmission assembly in two price ranges, Level 2 and Level 3. Due to freighting costs neither of these options includes the center diff, but one can be provided as part of the assembly if required. This will cause some additional shipping costs. The level 2 gearbox contains a serviced/reconditioned standard OEM gearset, which is suited to an individual seeking an OEM compliant replacement gearbox. Comes with 12 months or 25,000 km, whichever comes first, warranty. ? Inspected and overhauled factory Hi/Low range gear set at 1.447 or 1.196 ? Inspected hubs and sliders ? Inspected synchronisers ? Inspected gearbox bearings ? Hi advanced bead blasted gearbox case ? Complete serviced fork and rod kit ? Serviced front differential ? Set to strict ADS specifications. Level 2 gearbox is $1950 AUD LEVEL 3 transmission assembly includes the following: The level 3 gearbox is the best option for reliability and longevity without any vehicle modifications. It comes with 24 months or 50,000 kms, whichever comes first, warranty. This option includes: ? High/Low range gear set 1.447 or 1.196 ? Revised 1-5 gearset (caroius ratios avaiable) ? Strongest turbo 3/4 gearset ? Lever action 5th gear hub ? New revised hubs and sliders with ball shift ? New gearbox bearing kit ? New revised synchronisers ? New OEM gasket and seal kit ? Complete serviced fork and rod kit ? Serviced front differential ? Hi advanced bead blasted gearbox case ? Set to strict ADS specifications Level 3 gearbox is $2450 AUD (minus centre diff assembly) Optional ISF and shot peen strengthening process $650 AUD The available transmission ratio's The dual range transmission comes in two ratios, either may be used depending on the application. The 1st and 2nd gears have 2 variations 3.454/2.062 or 3.54/2.11 The 3rd and 4th gears have 3 variations 1.448/1.088 or 1.36 -0.97 or for the late series 2 only 1.29/0.97 The 5th gear has 4 variations .738 or .781 or .825 or .875 The high low range ratio has 2 variations 1.447 or 1.196 The final drive ratio has 5 variations 3.7 or 3.9 or 4.11 or 4.44 Additional items that may be required when installing dual range conversion kit to either option 1 or 2 may be purchased from All Drive Subaroo ? Centre body interior console $125 AUD ? Dual Range lever and cable mechanism $40 AUD Used part or new part $150 AUD ? Hand brake handle unit and cable $150 AUD ? Clutch kit assembly is optional ? Front LSD differential units is optional ? Centre diff bearing kit $220 AUD All options are available and ready for dispatch within 2 to 3 days. Our usual freight company is TNT, whom we have found to be overall the most reliable and cost efficient company. All consignments are fully insured and your cost would be confirmed if an order is made. You can if you wish arrange for your own freight. Please let me know if you wish to place an order or need any additional information on these products The ADS team and I look forward to being of service to you. With Kind regards ADS Team Isaac Fam
  4. I just want to pull a rugged camper trailer down to Cabo San Lucas, Baja California Sur or the other way to Denali National Park and Preserve in Alaska
  5. You got it wrong, I don't want rock-crawling. But you go ahead. You need that drop for those tall tires. I want just good overland. I'm only planning a 2in lift or so with stock sized tires. I'm not going for this Maybe.. Just maybe good enough for the Rubicon trail, but that's not my goal. Should it be?
  6. happen to know the AUDM part number for the D/R center console in beige?
  7. Hi, I've been googling like crazy for the last few days, but I'm far from well informed. The car is a 2000 Outback with an EJ252 (8 bolt) motor. As far as I can tell, an appropriate tranny would be a TY754XKAAA or pretty much anything(?) with an 'X' as the 6th letter. What's the deal with D/R ratios? That tranny above would have a 1.19:1 reduction, but the gears from an early EA82 mated tranny is 1.59:1 (?) for a serious drop for the extreme I'm looking for but won't fit without machining? Or buy ready-to-go gears? Or drop the bucks ~$3900 for a fully prepped one from All Drive Subaroo in Australia with a sizable shipping charge? Texas JDM has an unprepped tranny for $900 Then there's the AU interior console for the range lever and maybe a dash indicator if I want to get it all OEM. Quaife ATB or Torsen diff? What have others done?
  8. Hi, I've had my 2000 Outback a year now and love it. At 210K miles, the EJ252 engine has the dreaded head gasket problem, but I'm watching it like a hawk. At each tankful, I need to move coolant from the catch bottle back into the radiator and replace about a 1/2 quart of lost oil. Engine swap will have to happen within about a year I'm guessing, but the problem isn't getting worse. I joined because I want to find more info about the Aussie 5MT dual range transmission. Is the TY754XKAAA the proper one to start with and mod for the 1.59:1 EA gearing? Quaife ATB or Torsen diff? I've got a while to plan this... no rush.
