Everything posted by slammo
Hood scoop and vents - IMO gold would look tacky; I'd stick to the OEM green for sure. On the bumper I think black would look better than gold for the style of bumper you're building where it doesn't really blend into the stock lines or imitate the OEM shape. /$.02 Fuel tank skid looking mighty fine! Might be worth your time to slap some POR-15 on those rusty brake cable and heat shield brackets.
Did you do anything with the pitch stop mount for the subframe drop?
๐ ฑ๏ธillet knuckles looking great ๐ My understanding FWIW, some of the appeal of the all-aluminum radiators is that the plastic end tanks on oem-type radiators can be prone to cracking. Where'd you find the Golpher for $300? I saw it on Aliexpress but with $150 shipping, and it looked out of stock on eBay but maybe I just didn't find the same listing.
Sounds like these guys have developed and maybe produced some; kinda pricey though. https://www.kobemotorsport.shop/post/r-d-subaru-liberty-outback-gen-iv-h6-3-0l-ez30-aluminium-radiator https://www.kobemotorsport.shop/product-page/pre-order-subaru-liberty-outback-gen-4-03-09-h6-ez30-alloy-performance-radiator
Looking great man, can't wait to see this thing yeet. Have you considered something like the holley hydramat for the fuel pickup? Would drastically increase the filter surface area and is supposed to help get every last drop out of the tank when it's close to empty. I understand they are kinda pricey though. Front subframe makes sense to be solid mounted because it has to carry the engine and provide strength between the frame rails in the engine compartment, since there's a big hole where the engine goes. Soft mounting the whole front subframe would mean those bushings would react loads from the steering rack, engine, and control arms all at once - not great for steering compliance, chassis feel, drivetrain alignment, etc. Solid mounting the front subframe lets the steering rack, control arms, and engine each be mounted with their own bushings that can be tuned for each component. Rear, the chassis is more whole above the rear subframe so there's less need for added strength/stiffness. The engineers would want some cushion/compliance for lateral loads for ride comfort, but they would want to prevent toe compliance so your rear wheels don't steer all over the place. If they had solid mounted the rear subframe and used softer bushings for the lateral links, then compliance in the lateral link bushings would cause the rear toe to vary with lateral load. Using stiffer bushings for the lateral links and (relatively) softer bushings for the subframe lets the system be comfortable but still keep toe in check since the subframe bushings can react moments across a wider distance. Rear subframe mount, my concern is that the bolts without bushings will induce more stress in the chassis at those points. If you have two solid mounts and four rubber mounts, the solid mounts will be doing almost all of the work. The rubber grommets sandwiching the subframe might help but probably won't do much for the lateral loads which would be the most impactful. IMO your best move would be to add an OEM-style rubber bushing to those middle bolts, but if you don't want to go through that trouble I'd say get rid of the rest of the rubber subframe bushings and hard mount the whole thing. That way lateral force can be shared by all six bolts instead of just two. I don't think any decrease in ride quality is much of a concern in this context haha, and it might make it easier to mount the gas tank skid plate.
I'm just going to hack away with the angry grinder until it all fits ๐ Although I'm going to do a better job at re-sealing the body than I did last time. Ditto on loving the aluminum spacers; I guess you're making those separate from the trailing arm spacers since you plan to remove the trailing arm spacers when you lengthen the trailing arms?
I would skip the center bolt for the rear subframe unless you plan on adding a bushing there. Several companies (Whiteline, Kartboy, Torque Solutions) sell what they call "lockdown bolts" that go here, with the premise of improving handling. I don't think it's a good idea for off road - I'd want to retain some cushion for hard impacts. Great idea, when can you make the first set ๐ I'd at least weld the inner perimeter of that opening
I've heard that you can flip the driveshaft carrier bearing upside down to compensate but I haven't tried it. Are you going to sleeve the chassis where the subframe bolts go, in addition to sleeving the spacers? Any other preventive tactics to address the infamous captive nut issues?
Nice progress! That trip was a blast, thanks for having me along. Reinforcing the strut tower tops and converting the GC to GD size is relatively common: https://rally.build/products/subaru-impreza-gc-weld-on-strut-top-reinforcement I like the principal of these being cut to shape and welded to the adjacent sheet metal, should help strengthen a little more. IIRC the center hole has to be opened up for normal GD struts too.
I'd guess most of that heat was from brake drag owing to the loose bearing, not the bearing itself. Might not be a bad idea to flush the brake system, or at least bleed it. I stopped getting update emails for this thread a while ago so I haven't been checking in as often.
Trip looks like a blast, wish I could have gone. You could get rear knuckles from a 5x100 sti and use stock 04 sti rear axles, but those are fitment for rear brembo or 2-pot brakes, neither of which would fit inside those 5-spoke OEM 15" wheels. I suppose it might be worth swapping the brake backing plate. At the end of the day, the stock sti rear axles aren't all that strong either, but they might get you by until the billet knuckles and diff stubs are ready.
Yeah this was a really fun trip, not too much carnage to repair afterward. The other guys were hesitant to come down to Big Bend but I'm glad I convinced them to check it out at least once. The Flexus definitely did some things well; the low range and articulation being its key advantages. Only the center diff locks; the front and rear are open so the traction control works pretty hard whenever a corner gets light. Without the brake-based traction control it'd be a real pig lol. Pontoontodd is right that the higher center of gravity is definitely its biggest limitation for most of the stuff we were doing.
What hose was this? One going to the oil cooler?
The HiPer strut design accounts for some steering geometry correction, but it will do nothing to address the strut bending issue that is arguably the biggest problem with adding track width. I for one am glad you did inverted struts; maybe a thick shaft would be "good enough" but I wouldn't trust it for heavy use. I think there's good reason that any rally suspension uses an inverted design, as well as the other manufacturers that have entered the long travel Subaru market (Flatout, Gorilla, etc). I'm really looking forward to having this setup on my car.
Sano switch panel. Yes, starting with a rust free body and reinforcing it before it starts breaking seems like a great strategy. Do you think you'll put the electric jacks in the new build? Seems like a lot of weight for little gain.
10.75 V still sounds pretty low. I had a similar issue in an 03 Outback where a starter worked on the bench but not in-car; it turned out to be several inches of wire in the leads to the starter were corroded. Replaced the leads and it worked great.
Cannot wait to experience this thing again. With a 6 speed and voodoo it is going to be unstoppable.
Sounds like a blast, wish I could have gone!
Lights below the headlights would have the same potential to contact the headlights as having steel there. If you cut the plastic bumper cover to fit, I think it would have enough give to be a non-issue. The plastic bumper might overhang the metal bumper though; not sure what to use in that case. More example pictures of cut bumpers because they look sweet: As for lights, I'd put them in the grille area and cut out the grille to make them fit. Purely aesthetic reason. Although if you could fit a super-long light bar between the lights and bumper that was the full width of the bumper, that would look pretty sick too. My vote for paint would be black rattle-can bedliner. Black because it's low key - I think gold would stand out and look really out of place, and if you use body color it will really highlight the gap between the bumper and body in a bad way. Rattle-can bedliner is inexpensive and easy, the texture will hide any imperfections, and when it gets scratched it's easy to touch up. Either color without texture will show off any dents or unevenness in the flat sections.
Looks sweet! Any plans to fill the vertical gap between the bumper and the fenders/headlight trim/grille? Pic example with cut bumper.
I'm shocked that they don't have more plunge than the OEM and good aftermarket axles. Isn't that 90% of the point of ball spline axles? I understand that removing the plunge requirements from the inner CV can allow more angle out of that CV; I guess your test will tell if it makes a difference. Curious how much material will be gone from the crossmember and control arm.
Would a leakdown test on your 99 H6 potentially show you where the cylinder pressure is escaping into the crankcase?
- long travel Outbacks or making Subarus faster and more reliable offroad
First off I want to say thank you to Pontoontodd and B for letting J and myself ride shotgun in this race. Our introduction to desert racing was definitely an experience for the books! I've been collecting my thoughts from last weekend to share here. The course was crazy rough. It was easily just as challenging as the Ozark trails we were riding on in April, but done at twice the speed. The small embedded rocks Pontoontodd was describing earlier basically felt like very abrupt washboards and were brutal at any speed. Several of the hill climbs might as well have been driving up a staircase, and they were steep, blind, and rough coming down the other side as well. I'd agree that the average Subaru with a lift and skid plates probably could have made it through the course, but it would have taken 4x the time and several of the climbs would have required a lot of momentum. Plastic bumpers would not survive haha. On that note, I disagree that a stock civic could drive it. Probably half to three fourths of the course's length would have been drivable by an average stock economy car, but they would not be able to negotiate the tougher stuff without modification or damage. I think we were lucky to only damage one tire and one wheel throughout the event. That your car held up for 3 1/2 laps and beat many more dedicated builds is a testament to the chassis and suspension modifications you've made. Most of the field of entrants was dedicated race machinery, and I only know of one other vehicle that was still street registered. I only took a couple photos and video of the weekend, almost all of which was during prerunning. Here are my brief video clips: Closing thoughts: For a lot of "typical" car enthusiasts, horsepower is addictive. Once they get some, they just need more and more and more. I'm pretty sure that in this crowd, suspension travel is the same way - you can never have enough, and you're always wanting more no matter how much you already have. It's a shame that there aren't more long travel options for Subarus, but I'm glad that yours are available and out there to show people what can be done.- long travel Outbacks or making Subarus faster and more reliable offroad
Would it be any easier to make an adaptor for where the bearing assembly bolts to the hub? 07 outback front: 07 outback rear: - long travel Outbacks or making Subarus faster and more reliable offroad
