Andymccauley
Posts posted by Andymccauley
On 6/30/2019 at 9:37 PM, FerGloyale said:
Cutting and welding the back end is the way to go. Good job. So much extra sheetmetal gone.
That thing is gonna wheel awesome with that much tire and no lift. Might have a low walkover, but otherwise it's gonna be sweet, no lift block weight, no blocks to rip or bend.
I admire this build for simplicity. Let's go wheelin when it's done. Brown's camp?
You live in the area? Still allot to do, runs n moves but I still need a radiator, fans and haven't even begun to start wiring, plan on starting all that after vacation
Been working on this thing quite a bit lately a year or more later, kind of went on the back burner for awhile.... Been cutting up the body to fit 235/75R15 tires...
Tacked the exhaust, it's done now, has some random fart can I had laying around on the end of it, O2 sensor welded in the J pipe I fabbed up
6 lug conversion is finished, learned one of my drum brakes is a gen 3 assembly, was having a really hard time finding brake shoes for it...
If only I had the time lol. I still gotta finish mine. Just got it running though..
Here's a video, about the 3rd time I started it after realizing the return line was leaking at the firewall..
https://m.facebook.com/story.php?story_fbid=1808120115899415&id=100001043335691
Hooked up the noid light and got injector pulse, won't fire though. got fuel, spark, injector pulse, I don't have an O2 sensor yet though.
Been awhile since I've even touched this thing. But made some progress yesterday. Got spark n fuel, not sure if the injectors are firing or not, might be missing a ground somewhere in the harness.
So I changed all the fuel lines underneath and figured out where I want to mount the fuel pump. Gunna run wires to it from where the plug was on the EJ harness.
Haven't had anything to update for awhile had to put a new clutch in the daily VW Rabbit. Had a tranny seal blow out and coat everything in gear oil, causing it to slip.
I'll get back to it soon.
The spacer I made out of 1/2" pipe and some longer m6x1.0 bolts, cut 2 peices of pipe to 5/8" roughly and had to back the cable adjuster out as far as physically possibly.
Looks like a wire bomb went off, lol! I only laugh because I am sure I will be seeing the same thing soon. I got a Beck/Arnley pump off ebay for $60.00 new. Suppose to fit a Loyale so I hope I am good with it. Going to try and mount it were the factory pump sits. Only thing I am not sure on is the clutch, I installed a new clutch in my my Brat about 75k ago. Guess I can decide to go with it are upgrade when I get there. Going to try and not be in a hurry. You seem to be coming right along!!
Depends on which route your going, just using the engine harness I imagine doesn't require alot of wiring.
Where were you planning on mounting the fuel pump? I'm just gunna screw it into the frame rail near the gas tank.
Are you swapping hte entire wiring harness into the DL? Like headlights, tailights etc? Way more work than needed to get a running EJ22. But I guess that's one way to put a tachometer into a DL. lol
Also, I see a fuel pump, regulator, and plastic filter up there in the spare tire well. Please tell me that's not the pup your using? That is a low pressure pump. And that fiter is NOT meant to be pressurized to the 35+ psi that the correct type pump will run.
you need a pump from a SPFI or MPFI GL/loyale or equivalent type replacement.
The original wiring in this thing was a mess, switches wired everywhere and random wires here and there. The dash is almost cracked in half too plus all the gauges will read correctly, ya I know it's alot of work, I've already done it in my rabbit when the ABA was swapped in but I feel like it's worth the extra effort. Just need to splice in lights, blower motor, wipers and ignition. Extend the fuel pump wires and brake light switch wires.
That is not the fuel pump I'm using lol. It was on the car when the Weber and ea81 were in it I just haven't removed it from the hardline yet. Don't worry, but good eye haha
This awesome peice of machinery.
I ran into more than a few connectors that wouldn't reach with the cluster sitting where it should also the driver side front headlight wiring was a little too far away too. So I pulled all the wiring back out and ran it how I originally ran it but this time yarded the blower box out. Everything reaches now hopefully this is how it's going to sit for good for the most part anyway.
Also put the plug wires in, put a oil filter and some oil in it too.
The stock lines work fine for a ej22E swap it would be a different story if you swapped in a ej257 with a fat turbo and huge injectors. I've ran my ej22 swap for a couple years with no problems without a surge tank.
What year?
I was big into the minitruck scene years ago, when the B2200 trucks are converted to EFI they have nearly the same size hardlines as this DL. So I figure it shouldn't really be an issue.
Well, I'm interested to know what you do. I think I read a post in some thread on here by a person who ran all the stock stuff for years and never had a problem... I do wanna build a surge tank eventually.
Well I've been wondering about that. So instead of wasting my time at pick n pull, and because the weather is crap lol. I ordered a barb adapter and some 1/4" efi hose. If it doesnt work that well, I only spent 15 bucks so not a big deal. I'll just have to find a hard-line then.
I went with the barb adapters and my stock hard lines. I thought about running a bigger line but then realized that no matter what you do, if you don't put bigger barbs on your tank it doesn't really matter how big your lines are further down the supply chain... at least that's my thinking about the matter. I haven't run it yet but hopefully it'll get enough fuel as I have it set up.
That was my thoughts as well but if a bigger hard-line can some how be attached to the tank without restriction it would flow better.
Thinking about getting this fuel pump, I know it's made in China... But it's the cheap, new cheap. So I'm debating it.
Gunna hit pick n pull this weekend and try to rob a fuel feed hard-line out of a EA82. I guess I'll figure out how it might work with the DL tank after I get it.
If it doesn't I'm debating on getting some 1/4" efi hose and some 5/16" to 1/4" barb adapters and just using the stock lines
you will get improved caster angles if you spin those strut tophats 180 degrees.
When I build a lift I'll remember that
This is what was all wired into rear taillight harness with some on/off switch as well
Got alot done the last few days, modded the torque strut to bolt to the adapter plate. Cut it and threaded the rod to m10x1.25
Started routing all the wiring, gunna have to extend some things but not much. After wrestling things in and out out the raintray holes a couple times, kinda got things to fit, the fuse box and ECU are going on the passenger side.
Bolted the header on, I'm missing a stud for some reason though. Got lost in the legacy disassembly.
Opened up the passenger side hole to fit the grommet in.
That's the part number I needed. Thanks!! I got two boxes from Rock Auto today myself. Probably be around the end of November before I start my swap. Going to do pretty much like you have. Clean it up real good when I get the 2.2l out. Ordered new seals for cams and crank, front main is leaking on my engine. Also new oil pan and valve cover gaskets. Have a Aisin timing belt kit coming in another box. R9/30 fuel line, clamps for FI and tune up stuff. My donor car is only showing 146k so I am hoping it is good to go. Been driving it back and forth to work. Almost hate to gut it, it drives pretty good. Has a far amount of rust, the Legacy, not my Brat! Following yours and hoping you have very little trouble. Thanks for posting and updating!
You should be OK as long as it's not showing symptoms of blown headgaskets I wouldn't worry too much. Mine had all the symptoms. But at 270k it probably should. I still have a list of things to get done, just really tight on money right now so not alot is gunna happen for awhile.
Got my drive belt from rockauto today, a whole 7 bucks including shipping.
- 1
I've been wondering about the fuel lines on this thing before I even pulled the EA out and I found a post last night about how the older EA81 cars varied in the fuel supply and return lines. Some only had 2 some had 3 lines. But the return is tiny, almost like the vacuum and return are the same size, I gotta follow lines and double check to make sure I even have 3.
It does you just have to make a bracket for it to mount correctly.
Good to know, my EA81 cable was in bad shape. The plastic liner was held on there with a house clamp near the firewall and was broken in another spot.
1981 Hatch DL 4WD EJ22 Swap
Posted
The rear wheel wells are now welded, sealed with silicone sealant and topped off with some harbor freight bedliner. Tires clear the rear with about a 1/2"+ from the body, so the next adventure is lift because the front tires don't have enough clearance to turn.
