Popeye.Tom
  • Location
    Medford, Oregon
  • Referral
    search engine, probably on cat or front oxy sensor
  • Biography
    Engineer, sailor, hot rodder. (had to search the star constellation - didn't know that!)
  • Vehicles
    2007 Subaru Outback wagon
Recent Profile Visitors
401 profile views
Popeye.Tom's Achievements
Newbie
Newbie (1/11)
0
  1. Hi all, 1 - Thank you one and all for the replies and suggestions! 2 - Many apologies for the "run silent, run deep" Buried at work and spring chores and getting back onto looking at the computer after 10+ hours then chores isn't something I could bring myself to... 3 - I am kicking myself for not doing some other basic tests (like a compression check) or leak down. I do not have a leak down guage, but the root cause appears to be a failed cylinder 1. I see only ~60PSI on 1 and 180-210 on the other 3 cylinders. :-( A friend (good friend) actually loaned me his bore scope. Not easy to use, at least for my first time. With the right angle mirror it seems hard to get a clear view. I could identify an open valve in one or another cylinder & the residual crosshatch is clear on tops of bore and sides, harder to see the lower "face" of the bores since the cable droops (I think.) BUT after fiddling and playing around, I think the bottom face of #1 is smooth, no crosshatch remaining and also has some micro-pitting of the wall. Now that I've actually read the instructions, I'll go back in and see if I can take some pictures that show anything and I'll post them. @brus brother I didn't swap, replaced coil and no change (this like everything else I tried was before I ran compression - I 's a dummy that way!) @idosubaru * It wasn't using oil in any appreciable amount. My daughter was putting in about 1 quart / 6 month change, maybe 4k miles. * I didn't check fuel pressure. * Did notice that #3 was leaking at the rail, put some reman injectors in and will rebuild the ones I took out, test and save as spares. >> NO Change on #1 miss. * Besides compression test, did run w/ vacuum gauge on intake. It was not stable - could see "vibration" in intake vacuum. Also, could hear the miss in the exhaust (stock mufflers) at idle. NOW I will pull the engine. Don't think I'll try to rebuild - have too many other projects for that. This was an LKQ used engine. I have not tried a JDM pull before. New Questions - (If I've not burned my bridges w/ slow update) A- What are your thoughts and experience on JDM pull. My mechanic buddy that loaned me his snapon bore scope has a dim view on them. His comment, "if you knew you were going to have to dump it in x years, would you change the oil?" I think this is overly pessimistic 'cause I'd think you'd do enough required maintenance to keep warranty in effect! B- Any recommended JDM dealer/source? I'm on US west coast, Oregon. C- I'm seeing more 4th gen 2009-2014 engines now than 3rd gen 2003 - 2009. i) Can a 2009 → 2012 (EJ25, pre FB25) work w/ my harness/ECU or ii) Is the 2009 → 2012 EJ25 long block compatible with my earlier SOHC EJ25 heads. I'll do head gaskets on any replacement so swapping heads if it will work w/ the long block and then fit in car. I kind of hate to dump the car. The body is straight/no rust, have really new Toyo Observe on factory steel wheels and even newer Michelins in factory alloys. Just put a radiator in 4 months ago... Thanks for all your help! Cheers, Tom
  2. Oh, it is a 2.5 AT car. Thanks in advance for your thoughts and ideas! Tom
  3. Hi all, This car (2007 Outback Wagon, base) was purchased a few years ago with a blown engine. I put a used engine from LKQin it. It got new timing belt, head gaskets, oil & water pumps etc before going in. It's been pretty good, all things considered. But ,for a long time I had nagging Cyl.1 misfire and a cat efficiency. I'm managed the cat, but not the misfire. >> I did see some fouling on the plug from #1 yesterday... << I have since putting in the used engine, I have done the following in the past 12 months... - Exhaust (not factory dealer) - Plugs, NKG (I'd have to look at which p/n - Plug wires, Belden - they didn't have the NKG and when I did the plugs #4 wire broke at the plug & couldn't wait - radiator - reman injectors (last weekend) I have run two cans of Jectron cleaner through with full tanks of fuel. The bloody check engine light will go out periodically. It has been out a couple of times (on it's own) since doing the injectors, but it comes back. I cleared codes yesterday and it came back about 30 minutes (of driving) later in the second run time of the short trip. I pulled 1 & 3 yesterday evening. Plug 1 did show not as clean & correct color as 3. Some fouling, can't say if it was oil or rich. I swapped 1 & 3 plugs when I put them back in, I'll have to pull and look at them now. I measured resistance for the Belden wires on 1 & 3 and they were close to each other and correct range for radio suppression wires. The engine definitely seems smoother at cold start idle after the injectors and I thought that was the end of P0301, but no! I do find it is idling low and rough after the code reset yesterday, but maybe that's just the system learning again. >>> I have run run a compression test. I will do that and report the numers. Maybe #1 is simply dead, but the car can get average 25 +/- mpg in general driving and low 27+ in highway, doesn't seem like numbers for a 3/4 good engine! >>> I've not replace the coil. Do I just do that next? (it is not COP, unfortunately) ??? This has the little 4 square coil pack and regular plug wires. Is this a "waste spark" type ignition and is there another "corner" of the coil I can swap out plug wires for a test? Please make suggestions for next steps! Parts, tests. Where would you go with this next? My daughter has been driving the car to school & the tabs have expired and I cannot pass emissions with the Check Engine on! Thanks, Tom
