Everything posted by rzirker
Which year 2.2's have EGR in intake (for swap)?
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was afraid it was random like that. I appreciate you answering.
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I just found a good 95 to use, with egr, but I'd still like to know if someone out there could point me in the right direction for a list. Seems like it would be a very useful sticky.
Hi, tried to search but 2.2 and EGR wouldn't work. I'm wondering what year/model/trans had 2.2 with EGR. Doesn't matter if I have swap the Y-pipe. I know the 95 legacy 5 speed had one, but they are getting hard to find. Any others? Or other ways to do it? Also wondering if a 2.2 will swap into a 99 OBW. I know the 99's were an odd year. Thanks for the help!
No speedo and no overdrive. Any connection?
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand what other reasons are there for fourth gear to quit?
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow high is that? Been to maybe 4200 with no shift.
1999 2.2 Legacy, automatic, 100K, the speedo is not working and the tranny will not drop into fourth/overdrive even when warm on the highway. Stays up at about 4000 rpm to do about 60/65 mph. No CEL. Searched all over the boards and couldn't find any connection. Couldn't find anyone with just fourth gear out. Hoping it's the VSS speed sensor. ?? Any ideas would be apreciated.
Carfax please
Thank you thank you rzirker@yahoo.com
Bubbles in my coolant!! Dangit!
rzirker replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull your thermostat out to keep the pressure from building. Try to keep your rpm's below 3000 and you could last a long time. Worked well for me. Good luck.
Know any good Subaru salvage yards?
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX.... and they are?? All the ones I know are part of car-part.com. Thanks
I'm looking for a black hood for a 2002 GT wagon, which is turning into a difficult task, but I'm also looking for a good supply of random parts from somewhere other than car-part.com (though they are a great resource). Anyone recommend any other off-the-radar sources for Subie stuff? Thanks.
How to remove Forester tailight assembly?
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, I did it. 3 nuts on the Forester. Hairdryer blowing hot into the inside for a couple of minutes, steady firm prying pressure out and the black goo lets go just fine. And there was plenty of goo on the salvage yard replacement to just warm it up and press it back in. Thanks for all the help folks!
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmmm. Ok, sounds a little extreme, but I'll try some heat tomorrow. Thanks for the reply.
Have a 98 Forester with a broken tailight lens. Took a couple of 8mm (3) nuts off the inside, tried prying, doesn't seem to want to let loose. I don't want to break more stuff. Anybody done this? Please advise. Thanks!
Online Parts Suppliers
rzirker replied to usaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI second that. And I get it shipped to Ohio. Still the best deal and best service. Wouldn't shop anywhere else.
head gasket part number
rzirker replied to cls1000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it is the 2.5, then yes, that is the right part number.
Notice: Wholesale OEM parts from Auburn Subaru
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXForget the website. Call 866-528-5282 and ask for Jason in "parts". write it down
98 OUTBACK help please
rzirker replied to robb1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPrimary check: Put your nose in the plastic overflow tank. Smell exhaust/oil/gas? Subtract $1500 from the price. (and even if you don't smell anything but antifreeze, you know those head gaskets will blow soon.)
Need 99 Forester 5spd tranny. Is 98 or 00-01 interchangable into a 99?
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut a 2000 5-speed in and it worked fine. So glad. Rear end is the same in all Foresters through '04. Also want to mention an engine swap that a friend did, 95 2.2 into a 98 Forester, worked fine too. Noticable lack of pep though. Thanks for the comments and suggestions.
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich tranny? Down to a 98 or up to 00-01? Rear diffs are all the same ratio. Thanks.
99 Manual trans is shot. They are hard to find and pricey. Can I rig a 98 Forester 5-speed or an 00-01 5 speed tranny into it?? There are lots of them and they're cheap. Maybe have to take 4 of the engine bolts out? Anyone tried swapping one out? Swap swap. Thanks for any ideas.
Another A/C question
go to wal-mart, buy a can of recharge for $12 with a coupling on the end. DIY doesn't get much easier than this. If you have a problem with Wally-World, go to Auto-zone and pay twice as much.
2.2 engine swap- 95 legacy into 99 Impreza?
Anyone know if this will work? 95 legacy 2.2 has dual port exhaust and EGR. (Got it originaly to swap into a 97 OBW) I have a dual port Y-pipe (from the legacy) if the Impreza is single, but are the lengths/fit the same? If you've done this operation or if you at least know if the 99 2.2 is single or dual port exhaust, it would help me out to hear about it. Muchas gracias.
Subaru Parts Online
rzirker replied to usaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAbsolutely the best? Jason at Auburn Subaru 866-528-5282
'95 2.2 into a '96 2.5 egr question
rzirker replied to rzirker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's the info I was looking for. Let me know what you find out about the wiring. Thanks.
I searched around but couldn't find anything on this. Problem: the 2.2 I bought has no egr on the manifold. has dual exhaust ports, but how do I remedy the egr issue when swapping into the 96? Any related wiring issues? Also, the 2.2 is from a 5 speed and the 96 is an auto. That OK? Thanks for the help.
