edvib
Everything posted by edvib
  1. Replaced engine temp sensor..., didn't help. Found 2 codes - 11 and 22...
  2. Thank you! I changed trans fluid some time ago, but didn' t check the level for some time. Also I replaced sparking plungs and plug wires... It must be some transmission sensor or TCU, or as you mentioned above engine temp sensor. If I' ll solve the problem I'll post!
  3. The problem started when outside temperature is about 0 degrees Celsius or below ... There is no problem to start the engine. But after I start driving when I have to slow down (near crossroad) engine stops. After about 10 minutes driving everything is normal. Thank you for your advise about engine temp sensor. It may be the reason of my problem. I' ll look for replacement and then check. About "Power" light - on gear box switch I have a button for fast acceleration. When I push the button the green "Power" light on panel is on. Found some information if Power light is blinking may be some problems with Transmittion control unit (TCU). I don' t understand much about automatic transmittion but us I understood there are TCU and several solenoids... May be in cold weather until it warms up something malfunctioning... But anyway thank you for your advice about engine temp sensor!
  4. I replaced IACV but it didn't help! When car is idling there are no problems! Only problems happening when I'm driving with cold car! The check engine light is off! No repairs or maintenance done before this begam! It seems to me it started gradually! It seems to me that there may be some problems with automatic transmittion. Today when engine stopped Power light on pannel blinked. Heard something about transmittion control unit... Thanks!
  5. Hello! I have a Impreza 2000 AT. When car is cold when I'm not driving the engine works properly. When I start driving in "Drive" mode till I touch brakes the engine turning off. It's like the automatic transmittion don't allow to switch gear. I changed sparkling plugs, MAF, iddle ect., nothing helps. When engine warms up, everything works perfectly - engine, automatic transmittion... May be someone had similar problem and have any suggestion whet to do?! Yours sincerely - Edvib P.S. Sorry for my English!
