Overlander
  1. I got it wired up. It runs a bit better but still boggs down when the throttle is applied. I'm sure I've got other issues to work out tho. Thanks for the help.
  2. I can see the remaining wires coming from the firewall but everything on the tps is gone except the metal connectors. It is a SPFI. Even when I go to the parts store they can only find the 3 pin sensor. But from what I can see this one was factory wired for the 4 pin it's got. My Chilton shows the tps as being for a 2.2ltr. Mpfi.
  3. Hello everyone, new to the forum. I have searched around a bit but could not find the info I was looking for. I have a 1990 loyale that hasn't run in quite a while. Over that time rabbits had rotten under the hood and eaten a bit of its wiring. I recently got it started and have replaced most of the eaten wires. However all 4 of the throttle position senor wires connecting to the harness are gone. Would anyone be able to get a picture of the orientation of those wires into the tps? I have been able to find 3 pin versions all over but not the 4 pin which I believe is a later model part. Thank you for your time.
