Hey super new. And there is probably a good forum you can point me to. But here is the issue I am having with my 1989 FWD GL.
	I just bought the car it has 100,000 miles and looks to be in ok condition. While driving it I noticed it was slow going in and out of gears and had a lot of trouble in reverse. When in reverse It would rev and slowly back up like a boat then it would get more traction and be fine. NBD I thought, it was old and cost me a couple of hundred bucks and when it goes bad I’ll put some hair on my chest and learn a bit more about cars. Lol.
	The next day while driving the transmission decides that going into gears isn’t cool. Press down on the gas and it revs like it’s in neutral.
	I check the fluids. (Which I promise I was going to do that that day.) Everything looks good except the ATF is empty. That can’t be good. So I fill it to proper levels at proper temps. Shift through the gears. Drain, clean the atf filter and pan. Refill.
	The car still doesn’t move. It’s not leaking any atf. Not a drop.
	So after some research I have a few ideas.
	Governor  gear getting apple cored.
	Vacuum Modulator sucking atf into the engine and burning it.
	or
	A host of issues that all at up to transmission says no.
	THANKS IN ADVANCE!
