KevinP
Everything posted by KevinP
  1. Do you know if a window from a 90 loyale would fit?
  2. Do you know if a window from a ‘90 Loyale would fit?
  3. I am trying to find a replacement back glass for my 87 GL-10 wagon. Will a back glass from an 89 GL-10 sedan work? Any one have any recommendations?
  4. Thanks for the tips. It is not a touring model. No hits as of yet on that website.
  5. Greetings all, As the title reads, I have an ‘87 GL-10 wagon. The back glass is shattered, and the only thing I’ve found so far as a replacement is the back glass of an ‘86 DL sedan. My question: will it fit? Thank yall!
  6. Good morning all, I posted a while back about a fuel pump, which thanks to y’all’s help I was able to get replaced. However, a new problem has arisen. My 87 GL-10 wagon isn’t running well. This morning it started up fine, but began to misfire and sputter when I put it in drive. I replaced my spark plugs and fuel filter, but now it won’t turn over. I have a Haynes Manual to go on. Does any body have any idea what it could be? distributor cap and rotor maybe? thanks, Kevin
  7. Thanks Sam. You da man. did you have any problems with pressure? Did you have to put in a regulator or anything?
  8. Hey guys, I have an ‘87 GL-10 wagon, (Fuel-injected) bought it last month from an owner who garage-kept it. Great little car. My fuel pump started leaking from the little bell on the back of the pump, which I would assume is a pressure relief valve. I’ve been looking for a replacement pump, and finding an original pump is impossible. Napa, Rockauto, autozone, partsgeek; nobody has one. Now I’m thinking of just getting an aftermarket one... anybody out there have a suggestion of a good pump that will work?
