Triox64
Posts posted by Triox64
@el_freddo yeah, that was my bad. I thought the forum might post the vehicle I had someplace in the left column, considering it asked. But, like I said, the rocker arm markings were my main concern. Have tolerances and what not for everything else.
- 1
On 7/25/2021 at 12:03 AM, GeneralDisorder said:
The shims are labeled. It's etched into the side of them. You check lash with feeler gauges and then you order different shims if any of them need adjustment. The shims are REALLY small though. As in you'll easily lose them if you drop one. Think of a disc about 1/4" in diameter and a few 16th's thick.
GD
I got most of that stuff figured out. Was mostly interested in the difference between the rocker arms, considering the markings.
- 1
59 minutes ago, GeneralDisorder said:
You can juggle them all you want but since the shims on those engines are TINY and must go back on the correct valve you best measure everything if any of those got mixed up. Best to measure all the lash and adjust any shims that need it anyway.
GD
Thanks... So, I'm gonna need a micrometer, I take it?.. Wasn't sure how critical it was, just knew the required clearance.
21 hours ago, heartless said:
With such a generic thread title, most people are going to look - does not mean they are able to answer the question posed, however.
I was one of those views - and could not answer you if I wanted to. Have never dealt with that myself, so...
Maybe in the future, be a little more specific with the title?
You're probably right on the title. I'm just a little stressed out, as it's primary means of income. And, I haven't found anything relating to it my issue over several platforms, somehow.
On 7/22/2021 at 10:01 AM, el_freddo said:
Geez we’re not on the clock being paid for giving advice!
I wouldn’t stress so much over roller rockers compared to lifter arms and push rods etc. But that’s just me. I’m sure (hope) someone might chime in on this considering your sarcasm/arrogance as a new forum member of 17hrs at the time of writing this!
All the best,
Cheers
Bennie
At the time I sent out the thank you it had over 50 views. But, to answer your other question, it's a FB25 engine from 2013.
Thanks viewers. Appreciate the help.
So, here's my problem. I was doing a gasket swap and the roller rockers for the cams fell out before I could get them marked. How important is the arrangement, beyond wear?
Noob mistake
Posted
@GeneralDisorder do you happen to have the lash specs? The link I saved is no longer available...
