linkthehero1234
Everything posted by linkthehero1234
I'm swapping an STi 6mt into my XT6 and have the center crossmember piece, but can't find the XT6 front and back pieces (my car is an automatic). Does anyone know where I can get those parts, and until then would it be a problem if I just used those from a regular EA82 chassis car and drilled holes to mount the EJ center piece?
Getting an engine and wiring harness out of a Tribeca for my XT6, the engine harness goes to the interior and splits, one section to the ECU and the other going up somewhere. Where does this go, does it connect to the rest of the car and if so can I just cut it? I’m guessing something that it goes to is the OBD2 connector, is there some alternative to taking the whole harness? I’m trying to remove everything from the harness that isn’t connected to the engine/ECU.
First, sorry if this is the wrong place to post, but I figure since it's mostly about the engine it goes here. I found a good deal on a JDM EZ30 and 6MT that I want to put into my XT6 (no problem with engine being newer). My question is, if I just put in a USDM ECU (or even the JDM one) will it pass California smog, or will I have to do other mods? I've read that if the JDM engine is the same as the USDM one it's fine, but it's not the same as the one in the car right now (ER27). Also, the car is currently registered in California but was originally sold in Washington, if this information is relevant. (I'm assuming they don't care about the transmission 😂)
Some XT6 Questions
linkthehero1234 replied to linkthehero1234's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok, I'll return it to pick n pull and use the store credit. Can I use the clutch pedal from an XT in an XT6? -
I have a mostly intact steering column clamshell from a 1986 XT 4 cylinder and one for an XT6 with the right side of the top piece broken. Is it possible to have these scanned so I can have the full part with the gap for the windshield washer stalk? Also, has anyone put 19" wheels on an XT6 (or other ea82)? Any mods required?
XT6 won't crank, out of ideas
the part finally came but because im stupid i put it in with the stub on the axle instead of the transmission so i hammered it to try and get it in, now the threads and bolt on the outer end are ruined, can i salvage the end from the old axle and get a new bolt? -
after 142 in the electrical section, on the foldout section for the 2.7l in section b2 -
also want to fix the weird wiring a previous owner setup because the thermoswitch died, what does this arrow with the K mean? -
i have a similar set from harbor freight, ill post an update once i get a replacement pin -
so turns out the pin broke inside the stub (no clue how i got it out) can i just get any 6mm pin and cut it down to size? -
ok good news i got the screwdriver out (tried to cut it with bolt cutters and it just came right out) bad news is now my 3/16 punch is stuck where the screwdriver was 😕 -
got a screwdriver stuck in the pin trying to push it out and a drill bit trying to push the screwdriver out, the inner part is 1/16 inch but i don't have a punch that small to push the screwdriver out -
i got an extra axle included in the pile of parts that came with the car and this one has good boots but doesn't have the part with the spline where it goes into the transmission, is it possible to take this off of the old axle and put it on the new one? -
it's not, its black or brown -
the joint is black but the grease in it is dark green, is that what you meant?
