Posts posted by msteel
Clutch is probably ok.
18-20 ohms is normal for most clutch coils.
The coil has become weak with age though. Common issue on these.
The easy fix is to remove the clutch face and remove a shim washer to tighten up the clearance of the clutch. This usually pulls the clutch in enough that it starts working properly again. Just make sure you still have some clearance between the clutch and pulley when the clutch is reinstalled. Don't need much, just enough that it doesn't drag.
Best way to test if it is the coil is with the engine running, run the AC until it stops working. Check voltage at the coil to be sure it's being powered (ecu is telling it to run) and tap the face of the clutch with a screwdriver handle.
I did read the voltage on the harness (unplugged the coil and read the connector) and open circuit the coil connector was getting decent voltage. The voltage would come and go as the A/C button was turned on and off. So it seems to me the control circuitry is asking the compressor to run.
I tapping the front of the clutch did not produce any effect - it did not engage, or try to engage as far as I could tell.
I think my next steps will be to one or more of the following:
* Check coil voltage with the coil in the circuit to detect excessive voltage drop in the supply relay or wiring.
* Bypass the supply wiring with a fused line straight from the battery and see if the clucth engages under those circumstances.
So, I think my A/C compressor clutch is bad (2007 Outback Wagon 2.5i Basic). I'd like some comments about whether my diagnosis is reasonable and any "gotcha's" in the replacement process.
I noticed my A/C quitting - intermittently at first then as time went on less and less often. It seems like it is more likely to work when the engine is cold, first thing in the morning.
When the air works it cools well, but it doesn't usually run very long before it stops.
I thought it might be low on refrigerant, but I put a gauge (borrowed my dad's cheap one from a refrigerant can) and the low side read 150psi, so I didn't put in any refrigerant and looked elsewhere.
When it doesn't work the clutch is does not spin.
Once when it was not working, I measured the voltage to the clutch coil and it was plenty - I think it was around 14 volts - but that was no load. The coil resistance measured 20 ohms, and from what I read several places on the internet the coil should be more like 3-5 ohms (really, the thing pulls 4 amps?).
Any other diagnostics I should try before I order a clutch kit? It seems Subaru doesn't sell the clutch separate from the compressor but I do see an aftermarket kit on amazon and the coil by itself on eBay so there are some sources.
Am I likely to have a pressed on pulley and have a hard time getting the pulley off with the compressor in the car?
Thanks.
Yes, my sister got checked out and was sore for a few days but seems fine.
As to her car, I don't have pics and am not at the car at the moment, possibly could have pics later today. The hit was square on. The center of the bumper is pushed in at least 6 inches, the hatch is crumpled and the spare tire area is affected at least enough that the hardboard cover won't sit flat anymore. The hit was hard enough that the car also sustained significant front end damage as it was pushed into the car ahead (likely would have bumped without damage without the rear hit).
I had not been aware of the subrfame recall until a few days ago and do not know if the car had the cleaning/rusproofing done under the previous owner. I can still ask him in case he remembers. Otherwise I suppose I'll have to have the dealer look up records?
My sister has the same 2002 outback as me. Mine has a rusty subframe that is starting to make me nervous. Hers is not rusty but it got rear ended a week ago and is totalled. If she buys it back from the insurance (she knows someone interested in the engine) I am considering if it would be wise to swap the rear subframe from her car into mine, or of it is likely to have been damaged in the collision. Anybody seen enough wrecked Outbacks to have an opinion?
Ok, well I finally got this thing back together. As several people suggested I put new flares into the lines under the rear seat. From there I ran a length to the factory unions and this part was pretty easy. I had bent premade lines before, but I hadn't done any double flares before so it took some practice on scrap and old lines to feel like I knew what I was doing. From there the line to the passenger side wheel was pretty straightforward. But I found the driver side line to be a royal pain as it went practically over the gas tank and had obviously been installed at the factory before the tank was put in. I finally decided on the tactic of bending the line as I fished it rather than ahead of time. This worked ok, but getting the bends right was more difficult that way.
Of course the rust is the reason for the line failure, but the rust also meant rusted bolts, trouble getting access panels off, broken rusted bolts, drilling and tapping out a rusty bolt, etc. I told my wife several times that when her dad offered me an amazing deal on his current Outback (which is how I got this one) that she should remind me how much I hate rusty cars.
I'm just glad it's back running after a week.
OK, well the leak is obvious now. It is at the couplings ahead of the right rear wheel. All four lines are pretty well rusted at the couplings, although the two that come from the front are in pretty good shape up until then. It it reasonable to put a new flare in those lines? Or am I faced with the joyous task of replacing the lines all the way from the proportioning valve under the hood?
a couple places it happens:
fluid is coagulating behind the piston caliper dust boots.
up here the rear lines that go over top the gas tank will start a very slow leak at first and you can't see it because it's just collecting/disipating on top the gas tank. when it first starts to leak it's not so much a hole as it is soaking through, weaving it's way around layers of scaled rust before it actually exits the line - it's sort of between a leak and no leak an may not leak unless it's under significant pressure - aka vacccum assisted brake booster, or while it doesn't seem likely - temperature/use dependent?
the master cylinders can leak between the master and the fire wall. i've seen this on a 2003 OBW, but the fluid leak was obvious as it was wet.
they have discs all the way around.
I hadn't thought of the fluid coagulating, that would explain not seeing a leak. I guess I'll have to pull the wheels then and check that.
Even though it's a southern car now, it does have rust from its early years in New York State, so I'll have to keep that location over the gas tank in mind. My previous Loyale had an exciting sudden brake line failure from a rusted line, and I'd rather not repeat that.
They have discs all around.
Remove the brake booster hose from the booster and stick your finger in it. If it is wet and smells like brake fluid, you have a bad Master Cylinder. This is not an unusual way for a MC to fail.
Thats the easiest check, after that look at all the calipers with the wheels off like Gary said.
There is only one vacuum hose to the booster, right? I didn't notice any signs of wetness when I checked it.
I had a mysteripus brake fluid loss in a 1995 legacy outbaqck to later discover it was leaking form a plug on the bottom of the ABS module and leaking down into the framerail under the airbox
The ABS unit does bear some investigation. It had a small amount of some kind of fluid, but I was thinkng it was engine oil that got there during the recent valve cover gasket job (had a misfire and found the plug seals were bad and plug wires were oily). I'll have to clean it off and see if it returns.
My 2002 Outback is losing brake fluid. I keep having to top it off. I have put in at least a pint in the last few weeks. It seems like it pretty much happens only in colder weather (which in this context is around freezing). I don't see any obvious leaks - no fresh spots on the ground. On a couple of occasions I have pumped up the brakes after shutting off the engine and hours later when I got back in the pedal was still firm. To me that makes it less likely I have a leaky line (unless the ABS keeps pressure even when a wheel line leaks in those conditions?) I pulled off the vacuum hose on the brake booster and didn't see any sign of fluid in the hose - so it didn't seem to me like the booster was leaking into the manifold. Any common places I should look next for this leak?
Just fixed these exact symptoms on my 2002 Outback. It was hesitating and then as the problem got worse, I started having small explosions in the exhaust. One cylinder was not firing and unburned fuel was getting into the hot exhaust. I replaced the plugs and wires (and the valve cover gaskets since the seals around the plugs were leaking oil onto them) and all was well again.
Success!
The combination of this loaner tool (OEM puller 27037) from Auto Zone:
And some hammering with an 8 pound hammer got it loose. Once it was out, the new axle went in easily. I disconnected the knuckle from the strut instead of the ball joint because I was also replacing the struts. And it needed aligned anyway.
Ended up just rebooting the CV joint and put it back to my car without separating the axle from the hub.
That sounds like a very safe thing to do.
Aside from the quality of the HF puller, would a good puller of this style be made to be hit?
In any case I'm out of time until Monday or Tuesday. Maybe the answer will become clear by then.
And I thought that now that I've left EA82 land for Legacy land, the axles would be tons easier :-\
Thanks for the suggestions.
P'Blaster has been on it several hours, but because the hub is still on the car it's not quite in a position to soak. I'm considering bringing the knuckle inside because I already have the strut loose and all I'd need to do was disconnect the ABS sensor and one end of the ball joint or the other. I'm a bit afraid I'll need a drill and a tap to get the pinch bolt out...
I'll have to see about Kroil. I've seen it but never used it. I also have some "Berkebile" I think, was in the car when I bought it from my father in law.
Never heard of hammering on the screw of the puller. That would at least give me something stable enough to let me use both hands on the hammer.
[EDIT - solved!!! See below]
Anybody got any hints for getting a stubborn axle out of the hub?
I have the nut off, and have the inner end of the axle disconnected from the transmission, but I can't get the outer end out of the splines in the hub. I've tried beating it out, and I have tried a 3-jaw puller, which resulted in breaking the puller (Harbor Freight...)
The car is a 2002 Outback. I suspect rust is involved...
My '92 Loyale 4WD wagon is approaching the 183,000 mile mark. It will take a long time to get to 200k because the Sienna gets all the long trips these days.
Check that the sensor that tells when the compressor is running is there and properly aligned. If it is not detecting compressor rotation then the clutch will disengage and the air won't be cold (because even though the pulley is turning the compressor is not).
I didn't see that sensor in the pictures. Now, my AC is the other one where the alternator is on the outside of the compressor, so I don't know where it is supposed to be on your system. But on mine it is on a bracket that goes over the belts and hangs over the compressor. The little "arms" on the compressor pulley pass by and it detects rotation magnetically.
I had mine come loose once while in Florida and was woried that it would be a very long trip.
It does sound like it could be a timing belt, with a valve stuck open on each head. But, if after all this there is still spark, then that means the distributor is turning, so the belt isn't broken in that case. If the cam is turning and you still have 0 compression, then it's the head gasket or something worse.
New distributor etc.
Have you rechecked the spark timing after the distributor was off?
+1 for the Thing in the Flywheel.
Until I got my father in law's Special Tool Made For That Purpose, I used a steel rod that came out of an old floppy drive. But if you use such an article, be sure you don't drop it into the bellhousing. If you do drop it into the bellhousing, do not try to pull it out with a magnet. Do not try to separate the engine and transmission. Instead, note that there is a removable plate at the bottom of the bellhousing. No need to ask how I know what not to do in this situation.
That was at least 200 posts ago
The amp is probably similar to a BU941.
Functionally, yes. But even that one has the collector on the tab, so it can't be mounted directly to the grounded heat sink.
I got lost after 'Jacinta is running'
then something something pdq zistor in a case with stuff makes magic thingys happen and it runs
Yeah, sorry.
But the big thing is that the round connector actually feeds 12v from the coil on to the condenser, not into the coil. So if you unplug it you won't read any +12 on the harness there.
The rest of the stuff is only going to be useful if you need the part today, can't get the real thing, and have the resources to build something functionally equivalent.
Jacinta is running!!!
I got an ignition amp from mdjdc and got it in this morning. Jacinta fired up the first time.
Because it is pretty warm (40's) this morning I am not yet convinced whether the amp was the original problem. The fact that it started right up does support that because a fuel issue would have probably required some cranking. Time will tell.
Along the way I learned some more about the ignition amplifier module and how it is wired. I'm sure many here know all this already but some this info might be of interest to others.
The two-bladed connector on the ignition amp is the input to the coil. It carries the ignition timing signal from the ECU (white/yellow wire) and power (black/white wire).
As best as I can tell the amp module itself is mostly an NPN darlington transistor with a protection diode, in a TO-3 case. Electrically, this is a common combination. However, because the TO-3 case is grounded through the coil bracket, it needs to be the emitter terminal on the transistor. This is is unusual since every TO-3 transistor I looked up had the collector connected to the case.
The ECU signal goes to the transistor's base, and the power simply passes through the amp module to the + side of the coil, and from there through the round connector to the condenser (capacitor) which is taped into the wiring harness. The collector of the transistor goes to the - side of the coil and becomes the tach signal. It also goes through the round connector to the regions beyond. The emitter of the transistor is grounded through the heat sink on the coil bracket.
They are close to a dead short,but,not quite.
Dead short across the winding would not kill the tach signal as long as the fuse held.
Yes, I realize that now. The thing is, my meter was showing lower resistance across the winding than just connecting the test leads together. That didn't make sense so I tried another meter and read 1.2 across the coil and 0.2 just shorting the leads. That difference of 1ohm seems to be right for the primary of the coil.
Even if the transistor wasn't bad before it is now. I destroyed it trying to rremove it from the bracket. It is not socketed like I thought. Rather it was bolted to the bracket, connected, and potted. Mine now has a loose lead (that is, wiggly inside the TO-3 case) which means it is definitely bad.If you have a "diode test" on your meter,use it to check for an open junction on the power transistor/ignition amp.
Would that I could. These cars are rare in junkyards around here. It may be I can find one. But they're all closed now until Monday.IMO you should get a coil w/bracket and amp from the junkyard instead.
If I can find the specs on the transistor I might be able to replace it out of my junk pile. So far I haven't been able to cross reference it. All I can say about it at this point is that it is in a TO-3 case and stamped 1501. From the way it is connected it could be a bipolar NPN. I expect it won't be too picky on specs as long as it can handle the currrent and the back EMF from the coil.
The primary of the coil reads a dead short.
If I understand how things work, then that would not only kill the spark, but also the tach signal and hence the fuel pump.
In any case it has lasted long enough and a new coil won't hurt anything.
2007 Outback A/C compressor clutch?
Posted
(short version)
Bingo.
(Long version)
My meter was acting funny so I replaced the batteries. Now it says the coil is 4.5 ohms.
I jumped the coil to the battery and the clutch clicked in (but engine wasn't running)
Looked at the my Haynes manual for wiring diagrams to locate the relay. Somewhat helpful but the diagram shows a different relay block than I have.
Finally found the relay by.....um....actually reading the cover to the relay block under the hood.
Removed AC relay, took voltage readings to verify the pressure switch was supplying power and things looked good.
Swapped the A/C relay with the second radiator fan and, I now have working A/C and non-working radiator fan.
Alas, none of the relays in my junk pile match (mostly they are from my '94 Loyale parts car), so I had to order one from the local parts store.
