Syd
Everything posted by Syd
  1. A friend is having this issue w/ his loyale. How can I check if the sensor is working correctly ? Also, can I have additional details about the location of the sensor ? Thanks Syd
  2. I've been driving the '92 legacy w/o thermostat for a year now without problems. In the winter time, I put a piece of cardboard in front of the radiator (about 80% the size of the rad). So temp is rising until normal operating temp (so I have heat). It takes a bit more time to have heat, especially at temp like this week with -10 farenheit. I remove the cardboard in summer time. I have a spare ej22 ('97 with 60k miles) for this car but there is no way to make it die, even with a HG problem... Syd Québec, Canada
  3. If you need a speedo I have a full cluster from a legacy, except the tach. Let me know. Syd
  4. If eventually you need a new speedometer, I have a whole cluster from a '95 legacy. bought it from ebay for the tach, which I installed in my '97 legacy. Syd
  5. All '98-'01 Impreza (except 2.5RS) All OBS ('96-'01) Maybe some impreza < '98 that were not brighton ?? someone can confirm? Syd '97 legacy brighton '92 legacy L
  6. I don't know for USA, but in Canada, there was the EJ18 engine with manual tranny for MY '97 impreza brighton. Syd
  7. bought one at my stealer a couple years ago.. Those plastic things are fragile, especially at -30 in the winter... Syd
  8. At least in Canada, Legacies that are not Outback or GT have the EJ22 engine until the MY99 included. From the MY2000, ALL of them have the EJ25 engine. Syd
  9. Randomize, Last winter I found a used '97 2.2L engine for my '92 legacy. It has 100k km and the timing belt is new. I paid 400$cdn for it, from a shop that rebuilds damaged wrx and 0-2 year old damaged subaru (most of them from the states). THe engine on the '92 legacy is still going ok, but with that small head gasket leak, I rather wanted to have something in hand to replace the engine. Unfortunatly I don't want to sell the engine But my point is, try to find a used engine for your car. Look in Québec if you don't find it cheap in Ontario... I'm sure you can find one pretty easily. Good luck, Syd
