Opie
Posts posted by Opie
PRESS RELEASE
2006 Subaru Challenge Customer Appreciation Event Series
http://www.SubaruChallenge.com
– July 2006 - Who doesn’t enjoy food, friends, fun and a little fast driving? Owners of Subaru manufactured vehicles are invited to do just that at a Subaru Challenge Customer Appreciation event. The 2006 season is just getting started (www.SubaruChallenge.com).
More Events and More Locations
For 2006 the Subaru Challenge Events are currently set to visit five states; Missouri, Maryland, Georgia, Florida and Texas! Each Subaru Challenge Event is your opportunity to have fun with your fellow Subaru enthusiasts and your opportunity to test your own Subaru's capabilities using Subaru Symmetrical All-Wheel Drive® system and your driving skills in a controlled and safe environment. Also each event will allow attendees to check out the latest 2007 Subaru vehicles from the local dealerships, many newly released SPT® (Subaru Performance Tuning®) parts, door prizes and a picnic style lunch & beverages. Be sure to make on of these events a “Must attend” event for 2006!
Since 2002, the http://www.SubaruChallenge.com web-site has provided an easy to remember, centralized location for Subaru’s customers to find information on the Subaru Challenge format of events. Since its creation, the Subaru Challenge web site has currently assisted in the promotion of fourteen (14) customer-appreciation events hosted by several different Subaru of America® regions including; the Southeastern Region, the Central Region and the Penn-Jersey Region. These fourteen (14) events have hosted over 1,200 participants since the Subaru Challenge idea came about. In 2004 the Subaru Challenge website logged over 217,000 visitors to its pages, in 2005 the website logged over a half-million visitors to its pages!
For 2006 we are continuing the Subaru Challenge style of customer appreciation events for the newly re-aligned Subaru Regional offices. Here is the current 2006 schedule:
2006 Great Lakes Region Event #1 - Kansas City, Missouri - Arrowhead Stadium - July 1st, 2006
2006 Mid Atlantic Region Event #1 - Baltimore, Maryland - Ripken Field - September 16th, 2006
2006 South Central Region Event #1 - Atlanta, Georgia - Gwinnett County Fairgrounds - October 7th, 2006
2006 South Central Region Event #2 - Gainesville, Florida - Gainesville Raceway - October 21st, 2006
2006 South Central Region Event #3 - Dallas, TX - Texas Motor Speedway - November 11th, 2006
Please visit http://www.SubaruChallenge.com for complete event details, On-line registration and more!
SubaruChallenge.com is also working to bring the Subaru Challenge event series to more locations across the United States including the Western U.S. and the New England area. Please visit http://www.SubaruChallenge.com for information.
The Companies
SubaruChallenge.com is an independently-owned company, located in Riverview, Florida working with individual Subaru of America® regional offices to promote and market customer appreciation events held throughout the United States online. Trademarks are owned respectively by the companies.
All the '06's already have the most current reflash...
You say your Spec-B has just over 1,000 miles? Give it to your first oil chamge (3,000 miles) and see if it has gone away...also make sure you are using at least 91 octane...higher if it's available near you.
I've got the Subaru OEM hitch for the '05/'06 Outback Wagon on my wife's Legacy 2.5i Wagon...it fits fine and the wiring connector is right where it should be...
The hitch is P/N: L101SAG000, just tell the dealer it's for your "Outback"
Well I decided to go ahead and freshen the spare motor as it's been a few weeks and the coolant and oil in the original motor are pretty well mixed...I'd rather not take any chances.
My spare motor has approx. 130k on it and came out of a car maintained at the local dealer for all of it's life, every Subaru recomended service was done. The car it was in was totalled in an accident but had no engine compartment intrusion.
I started on it last weekend, got the following done on Saturday:
Head Gaskets
Intake Manifold Gaskets
Valve Cover Gaskets & Grommets
Right Rear Cam O-ring
Rear seperator plate re-sealed
Rear Main Seal
Rear Wrist pin access cover o-ring
Oil Fill O-ring
Cam Seals
Oil pump reseal
Crank Seal
Resealed Oil Pan
Water Pump & Gasket
Thermostat & Gasket
Water Pump By-pass hose
Spark plugs
Oil Filter
Crush Ring
I'm waiting on a right rear timing cover (cracked) and one of the timing belt idler pulleys (noisey bearing) before I can get the timing belt and covers all installed and then it will be ready to drop in. Guess I'll start pulling the old one out this week to get it ready to go...
...I had forgotton how much fun engine work could be!
Subaru's official oil consumption info
Oil ConsumptionAn engine requires constant lubrication to reduce friction and heat and will consume some of the lubricant during normal operation. Oil consumption at a rate of 1 quart or more per 1,000 miles of usage may be considered unusual and should be investigated. Vehicles using less than 1 quart in 1,000 miles is considered normal and no repair or further investigation is required.
NOTE: Unless engine damage is evident, internal oil consumption testing or related repairs should not be performed until a new vehicle has been driven 3,000 miles.
Oil consumption is dependent on vehicle usage and may be at a rate higher than 1 quart per 1,000 miles prior to the first recommended oil change or during periods of continued high engine speed operation. Oil consumption may be excessive if the oil is not changed as recommended by the manufacturer. Therefore, ensure that the maintenance records for the vehicle indicate proper maintenance has been performed. If the vehicle has been properly maintained and oil consumption appears to be excessive, proceed as follows:
1. Check the engine carefully for oil leaks at all joining surfaces, gaskets and seals, on top and underneath the engine. Repair any leaks first, making sure that the location of the leak is identified and all oil residue is removed. If no leaks are found, go to step 2.
2. Perform a cylinder leak down test and record findings on the back of the hard copy. Perform appropriate repairs based on the results of the test.
I was assuming the poster was looking for info on installing a 120V outlet, not 12v "cigarette" plug... I didn't even know that the 120v outlet was an option.
Cool website Opie!
Steve
Oh...I thought that was a typo!
Hi, I have a 2.2l 99 Legacy with 14 inch alloy wheels. I bought 16 inch rims from an 03 Imprezza WRX. I have seem pics on the board here where people have put these exact rims on my generation of Legacy. I'm pretty sure the rim will physically fit, but my questions is about rotors. I need new rotors and an not sure which application to get. Looks like OEM and Brembo has a different part # for 14 inch wheels or 15 inch wheels. Would I get the rotors for the 15 inch? Lastly, if the total size of the tire is larger, will my speedometer be effected? Any advice would be greatly appriciated.
If the car originally came with 14" wheels you should get the rotors for the 14" wheels.
If the tire size diameter changes it will affect your speedometer/odometer, larger diameter will make the speedometer/odometer read lower, if the diamter is smaller, your speedometer/odometer will read higher. But the change should be very negligible unless your making a radical tire size change.
They are easy to put in, look HERE for install instructions.
Check my L7 website link below for more "New" Legacy/Outback info & tips!
Yes, I do, but I've since stopped using the cell phone charger and the fuse still blows. If I have bent the ears in the 12v outlet, should I just try and straighten them by bending them back?
Thanks.
We see that problem fairly often, it seems some cell phone chargers deform the outlets and cause a short. I'd unplug the 12v outlet harness and see if the fuse blows or not, if it doesn't you know the outlet is problem.
Do you use a cell phone charger in the 12v outlet that correlates to the fuse blowing?
If Jiffy lube just worked on it and she is on the way home check to see if the oil is way overfilled and the tranny is empty.
+1
Typical Jiffy Lube service...
If you guys pull the plug wires off the coil are the coil contacts corroded....or not shiney...thinking you might have a coil going bad...
See my similar post: http://www.ultimatesubaru.org/forum/showthread.php?t=50262
When all of the other cooling system work was done the car passed the gasses test...now it doesn't.
Bet your Forester doesn't anymore either.
Seems that once a Subaru is overheated it weakens the head gaskets and sooner or later you'll need to do them...at least the seem easy enough to do on SOHC motors...
...and the winner is....Head Gasket(s)!
I'm either going to install new Head Gaskets on this motor...or pull it out and install the "extra" 1.8L I have...probably take the same amount of time for either option...
What do you guys think...
Rebuild HG motor...
Freshen "Spare" motor and install...
The Spec C you are referring to on the Subaru Vehicle Inquiry Sheet refers to the engine specifications your car was built for. FHI uses the C code for turbocharged vehicle's, F code for normally aspirated vehicles. Yours is a standard USDM STi with some after-sale modifications.
you put all those new parts on it and didn't spent the extra $6 on a new rad. cap???? shame shame shame... :-\ Go buy a cap and tell us what happens....
Welcome too by the way....
LOL, I'm a cheap bastard...
actually I figured the radiator would come with a cap but didn't, so I just re-used the original one!
Off to Advance!
Does it have A/C? Power Windows? Locks?
If so, it is not a Spec C
What's the last 8 digits of the VIN, I can run it...
1995 Impreza 1.8L Automatic, 103,000 miles
After driving for approximately 30 minutes coolant begins to overflow out of the radiator overflow bottle.
Car has original radiator cap
Car has new radiator, new thermostat, new water pump & hoses
Do I have a bad radiator cap....or a head gasket problem?
Car does not overheat, it just overflows coolant...
I'll be pressure & gasses testing it tomorrow to be sure, but wondered what you guys think the more likely cause is...
Wish I could post a poll...
Our 2005 schedule is:
9/17 Aberdeen MD
10/1 Maggie Valley NC
10/22 Gainesville FL
Entry fees will be $30 and collected in advance via the web site registration. A light meal will be provided on Friday evening and lunch and refreshments will be provided at the event on Saturday. Each participant will also receive numerous Subaru freebies at registration and your own numbered door placards to run the event. Trophies will be awarded in each competitive class.
The event will be similar to last year. The courses should also be larger due to no GT ride and drive this year. We plan to limit driver participation at each event to the first 125 registrants to allow four heats and the Super Star Challenge to be run in the one day format. Go to SubaruChallenge.com for full details and to register. Also take advantage of the event hotel for you’re over night stay. We will have a Subaru only section in each parking lot for your vehicle's security and for admiring all of the Subaru’s.
Don't miss out on the fourth year of Subaru Challenges! Sign up and then get ready to have some Subaru only fun on an auto cross course. Each event will be sanctioned, insured and conducted by a local SCCA chapter.
Randy Reinhardt
Southeast Subaru
and:
We are still a couple of months away from the Maggie Valley and the Gainesville SUbaru Challenge events. Current registrations are 58 for Maggie Valley and 56 for Gainesville. We are excited to be going to these locations and we need at least 100 participants to make each event a success.If you haven't signed up or you know someone who is not signed up who should be,please get it done.
Don't forget to make your hotel reservations with the event hotels. NC will be in the middle of blue hairs hunting for fall foliage and UF is hosting parents weekend. We have rooms blocked for Subaru Challenge participants so don't miss out on the reduced rates. We will be hosting the Friday evening Welcome Reception at each hotel as well.
Maggie Valley: Quality Inn 828-926-0201 $89
Gainesville: Holiday Inn West 352-332-1615 $72
Here is a link to a picture of just some of the goodies that each registered participant will receive at the Subaru Challenge welcome reception /registration.
Randy Reinhardt
Southeast Subaru
That's right, the 2004 Subaru Challenge officially kicks off the 2004 season with it's first event at Arrowhead Stadium in Kansas City, Missouri on July 11th, 2004. Participate in the Subaru only auto-x competition, the meet & greet with other Subaru enthusiasts, see new Subaru products and load up on the giveaways. There will also be plenty of good eatins at the Welcome Party on Friday night! Don't miss this great event!
For more information check out http://www.SubaruChallenge.com
Sounds like the Cam Seals, quite common on Subaru's. The seals themselves are cheap, not sure about the cost to install them though.
Originally posted by alias20035
The Baja has been discontinued, 2004 will be the last year of it.
Do you have any other info on this, links, etc., this is the first I've heard of it being discontinued.
Cranking but not starting usually means you are missing one of two things, fuel or spark.
Are you getting spark to the spark plugs? If not the coil pack might have gone bad, just as a bad plug or bad plug wire could also cause this. Has the fuel filter been changed recently as it could be clogged, or the fuel pump could have gone bad.
Hope this helps!
05 Legacy 2.5I
Posted
I've got a 2.5i wagon that now has just about 30k on it, always used 5w-30 here in Florida with no problems. It's a great workhorse.
