dunkinman
Everything posted by dunkinman
Hello everyone, my is tom i am new to subarus I just bought a 1996 suburu legacy outback in very good condition body is mint you can tell this car was taken care of. well my question is at night when i turn on the lights my heater controls and my shifter selector does not light up could this be a fuse because all the instrument panel lights are on except heater controls and shifter selector. I know this isnt that big of a deal but if it an easy fix I would like to know i like everything working. it has a automatic tranny, 2.5 engine, and it has 168,000 miles on it. if you need anymore info just let me know. sincerely yours tom
hi there , i just bought it from the dealer runs great no engine light on but when i first drove it there was a check engine light on the dealer said they found a misfire on it replaced wires and spark plugs.and told me it was fine. i drive around town alot but i baby it. well when i first pick it up from deealer it was empty low fuel light was on so i filled it up with super it took 13.5 gallons now im under 1/4 tank and ive gone 154 miles.
hi there, I JUST BOUGHT A 1996 OUTBACK WAGON IT DIDNT COME WITH A OWNERS MANUAL. I NOTICE THAT ON THE SHIFTER IT HAS PARK-REVERSE-NUETRAL-DRIVE-3-2-1 MY QUESTION IS WHEN DRIVING AROUND TOWN DO I DRIVE IN D OR 3. DOES ANYBODY HAVE ANY INFO ON THIS SUBARU THAT I SHOULD LOOK AT OR HAVE CHECKED OUT. I DO SMELL A FAINT ANTIFREEZE WHEN I GO BY CAR AFTER DRIVING BUT WHEN I LOOK UNDER THE HOOD I CANT FIND ANY SIGNS OF A LEAK IS THIS NORMAL. IM JUST LOOKING FOR ANY INFO ON KNOWN PROMBLEMS WITH THIS MODEL. IT HAS A 2.5 LITER - AUTOMATIC TRANSMISSION - 166,000 miles SINCERELY YOURS NEWBE SUBE
hi my name is tom i tried to use my 4 wheel drive the other day and its not working usually when i push in the button on the shifter the light comes on but when i push it now it doent come on is there a fuse for this button if there is where is it. oh yeah during the fall sometimes the 4wd light would flash on and off like flickering if you will i dont know if it means anything but now its not working so maybe it does please help. thomas 91 subaru loyale wagon 1.8 engine 5 speed manual trannny
possible clutch promblem on 91 loyale
dunkinman replied to dunkinman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1991 SUBARU LOYALE STATION WAGON 1.8 ENGINE NON TURBO -
dunkinman posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
when shifting the gears it bucks after the shift . 2nd gear is the worst when shifting into 2nd it bucks the hardest have any clue what it could be causing it . now if i shift to 2nd at 2000 rpms and let out the real slow it wont do it . please help im a newbie oh yeah i almost forgot sometimes it wont shift into 1st unless i push the clutch in and give it a little gas wierd sometimes it pops out of 1st too. -
my 91 loyale is running rough also my check engine keeps coming on about 2 min after driving then every time i start it its not on only after 2 min of driving also i have a plug in the # 4 of the block that is bigger than the rest of the spark plugs like someone broke one before and retapped it so you have to use a bigger plug i dont know if this could mean anything but i thought i would mention it. also when i am at idle my oil pressure is almost 0 but when i am driving it . the pressure goes to 40 is this normal on a 5 speed manual transmissions.and could it have anything to do with rough idle or check engine light coming on after 2 min of driving.
91 loyale starting problem
no because i put the old one back in just to try it and it still wouldnt start it getting good spark -
i gave my car a tune up new spark plugs wires, cap, rotor. when i finished installing all the parts the car wouldnt start . so then i took the cap back off and i noticed inside the cap was alot of metal chips it looked like the rotor was rubing along the inside of the cap and cut through 2 of the metal studs almost all the way through. so i change the cap with the old one but it still wont start. could the timing be a factor its getting gas, has good spark, it cranks over but it wont start. please help
help spark plug promblem 91 loyale wagon
do you know the fire order on the block ? -
yes i tried your test and i do have spark on all wires but it still wont start -
you dont have a piture of fire order do you or can you explain fire order in more detail -
i was giving my car its first tuneup well that was a big mistake. when i pulled the last spark plug out i noticed that the plug was different from the others it was bigger than the other ones i thought i was losing it but sure enough it was. i came to conclusion that someone must have broke a plug before and drilled it out and tap it with new threads also i forgot to tell you that when i pulled that last plug there was some kind of rubber on it like gasket sealer maybe so i put the old plug back in but the car wont start. can anyone shed any light on this promblem please help.
