Just wondering if anyone has encountered this problem. I've had may subarus and othe models,and two have completely left me clueless. Problem is the starter will engage at times and others it won't, followed by the clicking sound of the solenoid. Whats odd is, I've gone as far as replacing the starter 4 times, and same problem. I usually can start the vehicle, by numerous attemps at the ignition swich. I've also made sure starter is well grounded, replace the ignition swich 3 times.Whats odd is, when the problem arrised, I can bypass the ignition swich , by adding 12v+ from the + side of the battery, utilizing a jumper cable to the Solenoid on the starter. It will crank over with no problem. This leave me with the conclusion, that I must either have a problem with a break in the wiring from the ignition swich harness to the wire that connects to the solenoid, or does subaru use a resister between this connection or other, which may be causing my problem? Any suggestion , would be appreciated. Thanks in advance. Hugo/ So. CA:cornfuzz:
