Search the Community
Showing results for tags 'Driver Cam Gear under Load'.
Hello, My Car: 06 Legacy 2.5 SOHC So I'm going to finally get my Timing Belt on. This is what I notice and I want to make sure it is all correct. 1. Crank Gear Alignment is correct : The Two marks Line Up 2. The Passenger Side is Lined up: There is NO Tension/Resistance to get the lines to line up. 3. The Driver Side is Lined Up: There IS TENSION/Resistance to get the line on the Cam Gear to line up with the line on the back cover (notch) Is that normal for the Driver side to be under tension? Sorry if this is a dumb or silly question... just want to make sure I am going this correct
- 7 replies
- Install timing belt
- Driver Cam Gear under Load
- (and 1 more)
