October 11, 200916 yr Hey y'all I was wondering the procedure for removing the a/c clutch. I got the pulley off the bad one( teh clutch was already missing), I can't seem to figure out how to get the clutch to come off. I see three small threaded holes. I'm guessing that this is part of the equation.
October 12, 200916 yr Just replace the compressor is the easiest way. If you really want to do it, you'll need an AC clutch puller tool, and an AC clutch installer tool. I think you can rent them from Napa for a small refundable fee. Google it and start reading. Each compressor is just a bit different, though they work essentially the same way.
