Question.
Will my 1987 EA-82 Bolt onto a 1992 Loyale? I think it will I just need to make sure for an intersted party.
Orion
If the '87 is a carb it will have ports on the bottom of each head that need to be blocked (Air Suction Valve ports), and will have slightly lower compression ratio. Other than that it will work just fine.
If the '87 is an SPFI engine then it's a direct bolt-in replacement.
If it's a turbo or MPFI engine, then it will not work at all.
Cool thanks, thats what i needed to know. Now the guy better call me back!
