Niku-Sama Posted October 16, 2009 Share Posted October 16, 2009 i dont get it, i've been able to pull them out of other cars but i cant seem to do it on mine. the cars in the junkyard, i undo the 2 motor mounts on the underside and i undo thepitch stop for good measure and i can uaully lift or pry the engine over enough to get the manifold out. my car i undo the 2 motor mounts on the under side and the pitch stop and it doesent budge! this is frusterating, i have a repaired manifold i would like to try so my turbo would acually spin! Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 16, 2009 Share Posted October 16, 2009 It might be caught up on the oil return line on the back of the head. Last time I was installing mine I pulled the line off and didnt know it......what a mess :-\ Quote Link to comment Share on other sites More sharing options...
Niku-Sama Posted October 18, 2009 Author Share Posted October 18, 2009 well undoing the motor mounts and pitch stop it should move right? it doesent move at all, like its still bolted down Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 18, 2009 Share Posted October 18, 2009 2 manifold bolts per head and the bolts/nuts holding it to the bottom of the turbo. Do you still have the heat shield attached? Quote Link to comment Share on other sites More sharing options...
Niku-Sama Posted October 19, 2009 Author Share Posted October 19, 2009 nope all the bolts on the underside of the manifold are out and the 4 are off on the base of the turbo, heatsheilds are off. this is kinda pissing me off because when i cant get it have to put it all back again because its my main car untill my injector o-rings get here. problem is when i have the heat on it sucks alot of exhaust into the cab. the manifold isnt the problem, the engine doesent move at all for it to give me any room to get the manifold out. its like its still bolted down to the motor mounts when its not. with all the bolts out, with a jack of a crane i lift the engine, the car still comes with it. Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 19, 2009 Share Posted October 19, 2009 Sounds like you may have to pull the downpipe loose from the turbo. Quote Link to comment Share on other sites More sharing options...
