February 2, 200422 yr I did a search and couldn't come up with this. Some time ago, somebody was talking about a different oil pump shaft seal for ea82s that moved the sealing point to a new, unworn place on the shaft. I thought it was WJM, but he said it wasn't him. Anybody know anything about this?
February 2, 200422 yr Hey Snowman, I think what you are looking for is on this site: http://homepage.powerup.com.au/~camncath/ea82_hydraulic_lifter_fix.htm "You can use a shallower seal and avoid the grooved section. The seal to use is a NOK AH0816E, which is identical in every aspect of the original seal but is 2mm shallower." This is a board member from Australia so I have no clue if the part number is valid on this side of the world.
February 2, 200422 yr discussion on the same topic. http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=6629&highlight=shaft+sleeve
February 2, 200422 yr Author Thanks, I called NAPA and they were finally able to find a sleeve for it.
February 3, 200422 yr Author well, Napa only has sleeves for loyales, which use a larger diameter shaft, but they were able to cross-reference the seal. For anybody that's interested, the part number for this magical oil pump seal is 7012.
