STI_Wolf Posted October 27, 2009 Share Posted October 27, 2009 ok.. 88 xt6 5 speed symptoms are.. When cold: intermittent power loss for short periods of time, usually fine after you give it full throttle. When warm: constant power loss till 5k rpm unless at full throttle, if you hold the gas half way or so, it sounds like its just blowing flames out the muffler, and looses speed.. if you unplug the mass airflow sensor it will run better, but cant reach any higher then 3500 rpm... adjusting the TPS doesn't change anything at all really, unplugging it makes it impossible to rev the car up at all. the person i got it from was following me and said that glowing pieces of metal were coming out the exhaust. check engine light doesn't come on during this, unless the MAF is unplugged. i have a couple ideas what it may be, but ill stay quiet to hear what you guys think:grin: Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 27, 2009 Share Posted October 27, 2009 glowing pieces of metal were coming out the exhaust. that makes it all worth it at least, doesn't it? sounds like the converter might be clogged. or it could just be too much fuel burning in the exhaust. in which case the fuel pressure regulator could be shot? how about generic tune up stuff - plugs, wires, cap, rotor, air filter, fuel filter, timing belt? Quote Link to comment Share on other sites More sharing options...
STI_Wolf Posted October 27, 2009 Author Share Posted October 27, 2009 how about generic tune up stuff - plugs, wires, cap, rotor, air filter, fuel filter, timing belt? all been done.. tanks even been droped and the whole fuel system has been gone threw exept for the injectors Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 27, 2009 Share Posted October 27, 2009 tank was dropped because of......???? if it was rust issues or something else then there could be a line, pump, or fuel filter problem. fuel pump has a sock on the intake side, might want to check/clean that if indeed the tank had issues. Quote Link to comment Share on other sites More sharing options...
xoomer Posted October 27, 2009 Share Posted October 27, 2009 Gary this was my Car, Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 27, 2009 Share Posted October 27, 2009 Gary this was my Car, oh no, it's a lost cause!!! seriously - if you have input into this stuff that will help him. Quote Link to comment Share on other sites More sharing options...
Redcap Posted October 27, 2009 Share Posted October 27, 2009 Troy, you pulled the cat and punched the honeycomb out yet? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 27, 2009 Share Posted October 27, 2009 Troy, you pulled the cat and punched the honeycomb out yet? oh no, PETA is going to start lobbying against and strong arming USMB!!! Quote Link to comment Share on other sites More sharing options...
Redcap Posted October 27, 2009 Share Posted October 27, 2009 oh no, PETA is going to start lobbying against and strong arming USMB!!! Quote Link to comment Share on other sites More sharing options...
STI_Wolf Posted October 27, 2009 Author Share Posted October 27, 2009 haha! oh boy... Quote Link to comment Share on other sites More sharing options...
STI_Wolf Posted October 31, 2009 Author Share Posted October 31, 2009 well, i got a little desperate and bypassed the CTS by hooking up an old volume nob.. just twisted it till it smoothed itself out.. so for now its drivable-ish, it still misses a little bit, but im one step closer.... now i need to get those other tires on.. Quote Link to comment Share on other sites More sharing options...
xoomer Posted October 31, 2009 Share Posted October 31, 2009 Hm.... CTS's actually go bad? cause that one was new... Quote Link to comment Share on other sites More sharing options...
