Flow Posted February 2, 2004 Share Posted February 2, 2004 Looking for a wiring diagram for this switch. I believe its out of an 89 gl wagon, not sure tho. I hope (with a little help from some of you electrical guru's) to wire this to a relay and aftermarket driving lights. Thanks. Link to comment Share on other sites More sharing options...
SubSandRail Posted February 2, 2004 Share Posted February 2, 2004 It is hard to tell from the small picture, but if it has six leads coming out, it is probably a standard dual-pole-dual-throw (DPDT) rocker switch. Go to : http://www.kpsec.freeuk.com/components/switch.htm Scroll down to the DPDT section for a description. It is really two switches with one control. The middle pins are the inputs, and you select which outputs to connect it to. You can verify this with an ohm meter. If it has an LED on the switch, it could be less straight forward. Link to comment Share on other sites More sharing options...
