96 outback atarting problems
I have a friend woth a 96 OBW and she is having a weird problem. She can start the car just fine, but once it gets warm and she drives it and then shuts it off for a brief period, it doesn't want to start up again. She said it just turns over and acts like it is flooded. I'm thinking that there is a problem with the coolant temp sensor.
Any suggestions would be much appreciated.
Mike
I had this problem in my '96 Outback. When I brought it to the forum it was suggested by a few that it's the crank sensor, they're prone to cracking and after a "hot soak" the crack can expand and the car won't start. The problem was intermittent and while I did change the crank sensor and the problem did stop happening, I never did know for sure if that was indeed the culprit.
Pull the Temp sensor connector next time it won't start.
If it then starts right up......you know that the CTS is the problem
IMO I have never seen an intermittently failing crank or cam sensor. I've only ever seen one bad one, and it was dead always.
If the car will start predictable cold, but not warm it's 99.9% a CTS issue.
