My 92 Loyale w/BugEye MOMO
I know it's a bit over board, but I like the feel. It will soon go back to factory after the snow:) Horn must be relocated in order to do this, unless someone can show/tell me how??? and No... I don't have cruise... :banana:
how did you do it??
It's magic ;)
Seriously, the steering shafts are the same size. I did'nt cut into the wiriing to find the horn. I'll eventually find an aftermarket wheel w/out an airbag to install but for now, I like the feel of this one.
Sweet. That's good to know. For some reason, I thought the steering shafts were different sizes
Fixed.
My horn now works. I found out that all I had to do was run the wire(It was a green/black wire) from the column to the inner bracket of the wheel, and it worked.
So you don't need any type of adaptor? I so want to change my wheel to a Impreza one, one that looks like the momo wheel you have but says SUBARU would be cool.
-Tom
-Tom
No adapter necessary. All you'll need after properly removing the steering wheel, is about 6 inches of wire to get the horn going. The hardest part of the whole thing was pulling the steering wheel off after it had been on there since the assembly line. Pretty straight forward except the wire part.
I'll be removing it soon to sell it. I found an aftermarket Nardi I like.
Cool, I'll have to do that this summer. Wiring is no biggie.
Thank you :)
