1992 Loyale wagon 4WD 5 Speed
N8NQU
do you have the green test connectors hooked up? they are required for proper timing checks...
Not sure where they are on the 92 Loyale - on the 89 GL they were just behind the drivers side strut tower - but from what i understand later models had them under the dash?
I am trying to check the timing and And I can't get my timing light to work on 1 cylinder??????but it does work on 2 cylinder.Any ideas???
Thanks Bill N8NQU
Bad cap and rotor, or bad plug wire or plug.
If the light will flash on all the other wires, those are the only options
#1 is passenger side front,Is what I am trying to get my timing gun to work.1-3-2-4.Merry X-Mas.Bill
just to be sure - what are you calling #1 cyl??
#1 is passenger side front - not drivers side front as many mistakenly think
the only other thing i can think of would be completely mis-timed - but if it was that far out of whack it wouldnt run... :confused:
Compression and therefore firing voltage is too low on #1 to trigger your light.
Try a wide plug gap on #1 or loosen the wire on the spark plug until there is a small gap.This will increase voltage enough to fire the light.I`ve had the same problem.
I will try that,Thanks Bill
  • 2 weeks later...
Finally I got the problem fixed,It turn out to be the new Cap that I got from Advance Auto.It was not machined right.I am glad it's fixed,I'll be having fun in the snow now.Thanks to all that took the time to follow this thread.Bill:banana:
