December 25, 200916 yr While trying to remove a hardened cam seal I slipped and scratched the inside surface where the cam journal rides. ( i know i know the right tool for the right job) The cam support is off the car. HOw can I clean this scratch up. Is there an easy solution? thanks in advance.
December 25, 200916 yr A picture would help to see the extent of the damage. Ideally, gently rub the gouge with sandpaper, dremel or the like. DO NOT take any more material out. Just remove the sharp edges. This will not hurt the cam. It will "hold" a little extra oil is all.
December 25, 200916 yr What he said - smooth it out for sure - you're not looking to change anything just smooth it out and remove edges. The ones I've seen didn't actually leak. See where it is, it might be further in than the seal is pressed. If you're worried about it or it did leak I would imagine some anaerobic sealant would be a good bet. Not that I ever recommend sealant on a seal nor do i ever do it - but this might be one case. That being said - if this is the EJ22 then it's the one with the removable cam cap, just three bolts. Might want to just go ahead and replace it or it's easy enough to replace if it does leak.
