Q: What's the best way to clean a turbo?
Can you dip it in chemtool? What's the best way? dismantle it and individually clean the walls and propellers?
This is out of curiosity.
Disassemble it and soak the individual pieces. Make absolutely sure you dont scratch up the thrust/ hydrodynamic bearings with anything abrasive, but you can scrub about everything else with a scotchbrite pad. Well, while you are in there, install new bearings/seals. $125 from turbo city. I'd recommend that over trying to get the used pieces back in there.
