87 gl10 turbo wagon
Hi all.. i just got a gl10 turbo wagon recently and i'm trying to find out more stuff bout this car. im from the bay area. new user to this site. im also a member on i-club too. well i just wanted to say HI to everyone. :grin:
make sure the radiator is in good shape.
you have an ea82 turbo engine, mpfi.
automatic or stick? this determines what axles it has.
most other parts are compatible with other models, such as brakes, wheel bearings, alternator, etc.
how many miles?
you will want to know when the timing belts were last done. engine is non interference, so if it breaks a timing belt, there is no damage to the valves
thanks for the info.
its a stick with the push button awd i was told that the radiator should be replaced this summer comin up. and the timing belts are already replaced last year and it only has 165xxx miles on it. all it needs is a new headliner, back bumper, the front main seal, and the two belts i have no clue what the names of them are. alternator belt and the one next to it.
ill try and get pics up later today.
also wat kind of mods can i do to my car?
holy crap thats clean!
thanks.
When you replace the radiator, make sure you buy a dual core. When I first bought Murphy, the $500 87 Turbo Wag a few years ago, I was having all sorts of issues with overheating. After blowing a head gasket (or two), i finally wised up and bought a dual core rad. have had no problem with overheating since.
And again, that engine bonnet is mighty pretty!
PS. Though I'm not English per-se, they all the engine bay a bonnet, so I just roll with it! :banana:
indeed. how do the eclipse subs sound in the back? did you expand the cargo box for additional box volume? or was there enough?
-Justin
the PO did it.. he said that its all fiber glassed and he didn't have to cut it. and they sound great i kind of wanna upgrade to a bigger amp and maybe 12's instead of 10's
thanks for the heads up on that.:)
don't think 2 12's would fit there.. least depth wise. that and usually 12"'s crave a lot more volume.. least the good ones :grin:. you might be able to cut into the body a bit and fab a new box. I've seen people do it on other cars.. Personally i don't like subs firing up from that position. it takes away from the cargo area and renders it pretty much useless.. even with a grille. IMHO of coarse!
-Justin
-Justin
i was told i might be able to run 2 kicker cvrs and a decent amp for them.
Like i said least the good ones. :rolleyes:. J/k. Kicker's are alright.. You can always lower the box a bit. looks decent though.:grin:
-Justin
kickers are good enough for me. and thanks
