Dizzy problem
I have an '82 gl that i converted to 4wd one day it just stopped running. I replaced the carb and the coil then i tested the distributer and the pickup wasn't working so i replaced that. It's still not running. Any ideas would be very much appreciated :banghead:
Distributor and coil need to match - 4WD and 2WD used different models of both. Get a matching set - that's probably why the pickup failed.
As to why it's not running - check for fuel and spark then go from there.
I'll try that thank you! i've got a rebuilt carb on it and a good fuel pump so hopefully it's just the coil and dizzy
