February 12, 200422 yr First i will say that english is not my mother's tong. I'm from israel, and thanks to the arab ban the only japanis car avalable was subaru' starting from the ff1 era to the wrx of today. we have a web page at http://planet.nana.co.il/subail/ everyboddy is invaited to pin a niddle on the map on the english page. anyhow. today a hob got loose and the macanic is saying that the hub on my 91 loyale station 4wd is difarent then the 2wd. he olso said that the hub of a brat 4wd will fit. so my q is: are the front hub of the 4x4 and the front wheel drive in loyale is the same? someone have a scatch with all the parts names? how much wuold it cost to reapair it in the us? its a5 speed 4wd 1800 carb 1991. (the last wagon in this pic) it use to drive p.m rabin when it was new!
February 12, 200422 yr ALL LOYALES, 1985 thru 1994, use the same FRONT hub for 4wd and 2wd. either will work. rear hubs are different a brat hub will bolt on, but the spacing for the rotor may be different. i would go with the 2wd hub for certainty
February 12, 200422 yr As for how much it would cost to repair here - not much if you got one from a Junk Yard, and installed it yourself (pretty easy). Maybe $20 worth of parts. If you got the stuff new and had a mechanic do it.... hundreds for sure. GD
February 12, 200422 yr Author here if i will lift the car with other then the "13 weel i will find my self of the road. my friend barry found a used copple of at tiers. my tirs are 175X70RX13:(
